Results 1 to 10 of 19
November 21st, 2006 03:20 PM #1
good day mga sir! pag tumatakbo kasi ung oto at naka-aircon, biglang namamatay ung makina? ano po kaya ung problem? kaya d muna k aircon ngayon...the car is a 94 corolla with a 4agze engine
November 21st, 2006 10:17 PM #2
have you throttle body and intake valves cleaned. pag madumi yan, nahihirapan yung engine pag tumatakbo at naka-on ang A/C.
check mo na rin yung A/C system mo kung madumi or sobra/kulang sa freon.
November 22nd, 2006 11:32 AM #3
pang-Workshop dapat yata to...
try browsing sa workshop section, baka may similar problem na.
November 22nd, 2006 02:08 PM #4
I used to have that problem. Without the A/C (aircondition) when coming to a stop..my idle stays at around 600rpm BTW i have an automatic tranny. But when I do that with the A/C on..my idle drops dramatically n sometimes it feels like its gonna die..it will hover around 500rpm. N sometimes with the a/c on n im driving..my car will die n i have to turn off the a/c..quickly switch it to neutral...start the engine..the throw it back in D (Drive). I just adjusted my idle a tad bit higher than what it was currently..n that helped. Because when i switch on the aircon, my idle will drop noticeably..so i just had to compensate. I have a 92 Senta a/t.
November 22nd, 2006 02:50 PM #5
palinis ko po ung throttle body and intake valves nia sa weekend. pinataasan k na rin po ung idle nia nun, kaso ganon pa rin, n besides d na rin economical kung patataasan k pa ulit ung idle nia. sabi ng iba, papalit daw ulit ako ng spark plugs para ititiming...may point ba ung idea na un?
- Nov 2005
- 311
November 22nd, 2006 03:44 PM #6hmm.. have you checked if the vacuum switch valve (vsv) is functioning properly, or there could be a leak in the vacuum system.
November 23rd, 2006 10:34 AM #7
Bro, better have it checked by your suking mekaniko to determine what is causing the problem..better do it asap..
- Sep 2005
- 103
November 23rd, 2006 11:03 AM #9Baka naman may problema ang idle-up ng kotse mo kaya pag on ng aircon hindi tumataas ang idling kaya namamatay makina. try mo pa chek ang idle up ng kotse mo.
November 23rd, 2006 06:41 PM #10
tumirik nga po ko sa parteng aurora kahapon, i did open the aircon kasi sobra init (tanghali kasi), pero pag magmemenor na ko, namamatayan na, then hanggang sa d na umandar...buti na lang naitabi ko pa, so jinumpstart na lang ng mekaniko kasi drain na ung battery. i'll list all the suggestions para madala ko na sa talyer sa weekend
https://www.youtube.com/watch?v=CEnGseEQxn0 Ford Territory Lemon Issue Debunked by Real Ryan.....
(2023) Ford Territory
