Results 1 to 19 of 19
    Nov 2006
    good day mga sir! pag tumatakbo kasi ung oto at naka-aircon, biglang namamatay ung makina? ano po kaya ung problem? kaya d muna k aircon ngayon...the car is a 94 corolla with a 4agze engine
    Aug 2006
    have you throttle body and intake valves cleaned. pag madumi yan, nahihirapan yung engine pag tumatakbo at naka-on ang A/C.
    check mo na rin yung A/C system mo kung madumi or sobra/kulang sa freon.
    Jul 2005
    pang-Workshop dapat yata to...
    try browsing sa workshop section, baka may similar problem na.
    I used to have that problem. Without the A/C (aircondition) when coming to a stop..my idle stays at around 600rpm BTW i have an automatic tranny. But when I do that with the A/C on..my idle drops dramatically n sometimes it feels like its gonna die..it will hover around 500rpm. N sometimes with the a/c on n im driving..my car will die n i have to turn off the a/c..quickly switch it to neutral...start the engine..the throw it back in D (Drive). I just adjusted my idle a tad bit higher than what it was currently..n that helped. Because when i switch on the aircon, my idle will drop noticeably..so i just had to compensate. I have a 92 Senta a/t.
    Nov 2006
    palinis ko po ung throttle body and intake valves nia sa weekend. pinataasan k na rin po ung idle nia nun, kaso ganon pa rin, n besides d na rin economical kung patataasan k pa ulit ung idle nia. sabi ng iba, papalit daw ulit ako ng spark plugs para ititiming...may point ba ung idea na un?
    hmm.. have you checked if the vacuum switch valve (vsv) is functioning properly, or there could be a leak in the vacuum system.
Help: namamatay makina when the aircon is on
