Results 11 to 17 of 17
January 1st, 2011 08:43 PM #11
Pag patay ba yung aircon ok ang takbo ng Surf mo? Was the engine "tropicalized" or adapted for use in a tropical country (the original was designed for Japan)? Yung head gasket na original normally sealed yung mga cooling holes. Pinabubutasan lang yun.
Notorious sa head cracking ang 2.4 to 2.8 na engine ng toyota. Less sa 3.0. You can minimize the chances of cracking by changing the head gasket to one with the cooling holes drilled/bored or enlarged.
Symptoms ng cracked head - loss of power, lack of power and torque, weak aircon (although the original Surf 2.4 weak ang airconditioning), overheating of the engine (may bubbles/bumubula ang radiator).
Kung cracked na head mo....wag sana....head replacement and top overhaul lang ang solution. If you undergo a head replacement make sure you tropicalize the head gasket.
goodluck.
- Dec 2010
- 89
January 1st, 2011 08:50 PM #12
ano po ba ipapacheck ko sa makina ko sir?? ano papatingnan ko para alam ko ano ung sasabihin ko sa mekaniko namin, tama pla yung compressor comes from the engine we purchased, ung condenser lng ang hindi, medyo luma ung condenser, dati pa itong ganito eh mahina aircon ,dati pa sa old engine.. pero me power naman yun kahit naka ac on ako.. eto minsan nawawala power ng hatak..
- Nov 2007
- 164
January 4th, 2011 01:46 PM #13pag patay ba ang a/c ay ok ang takbo?pag naka on lang ba a/c?pag nakaon ang a/c at humina hatak ay maaring naghigh pressure comp mo at maari ring nagbabackpressure..resulta nito ay maaring maging hirap makina mo..pero sa surf kadalasan ay pag naghihigh pressure o nag babackpressure ay nawawasak nyaang compressor..
- Dec 2010
- 89
January 6th, 2011 01:42 AM #14
sa awa ng diyos sir hindi pa naman ngoverheat eto and hindi ko rin hahayaan na mgoverheat eto.. and yung sabi mo na bubbles wala naman po ganun.. tingin ko my sira lng talaga ang compressor or something.. ano po ba yung mga dahilan nung pag crack ng mga head and anong paraan maiiwasan yun?? a/c on lang nawawala minsan yung power niya minsan naman hindi,
January 7th, 2011 08:56 PM #15
mabuti naman. pero ingat lang kasi nga overheating ang problem ng 2.4/2.8. mukhang sa aircon nga lang ang problem. good luck
- Dec 2010
- 89
January 8th, 2011 07:49 PM #16
- Nov 2007
- 164
January 12th, 2011 12:43 PM #17
Xiaomi E-Car
