Guys, where do you buy heat shields for the intake and cone-type filters? Anybody here had experience on this on their cone filters?
Most of the people I know with those on had them fabricated. Simota has a cone type model with a heatshield, if you're interested in changing the whole thing.
try contacting this number 09198339014, look for ms. grace sebanes, they are fabricating heat shields, maybe they can help you! :D
I used to have a cone type K&N w/o heat shield. I didn't notice any improvement over the stock airbox other than the added noise so I replaced it with a shielded type from ProCarParts. Then I went one step further by routing a flexible aluminum duct from the filter to the back of the headlights. Throttle response was improved considerably. The verdict: Cold air helps!:wink:
Thanks for the input guys! :D
Yo jorebo, I also have my filter behind the headlights, problem is mine is made of stainless steel. So I really have to use heat shields to lessen the heat my intake is conducting![]()
guys
factor din ba ung climate natin?sometimes...i noticed improved acceleration (although 1.3 lang car ko) pag malamig sa labas...ganun ba tlga?
may way ba para makakuha ng cold air ung car ko?
e w/o changing ung air filter set ko?
Originally Posted by meleagant8
8) Yes. Cold air is denser than hot air. More air (with more fuel) will give you quicker acceleration. I don't know what your ride is, but there are ways to get cold outside air to your intake. There are aftermarket CAI systems that replaces your stock intake or to save money, you can brainstorm something, maybe a ducting that will route outside air to you filter. I did mine with a flexible aluminum AC ducting from a hardware store.
thanks sir jorebo!Originally Posted by jorebo
hmm...my car is a lancer el 97 model...1.3 po siya...carb...and i was able to read somewhere na ung carb daw tlga affected ng climate sa labas ng car....
minsan nga im wishing na malamig lagi sa labas....hehe....
paano po ung ginawa nyo?
sensya na po ha,....im just new to cars so nagaaral pa ako...
meleagant8,
by "cold air", di ibig sabihin na malamig na air neccesarily as in malamig yung climate... basta cooler air than the usual hot air around the exhaust manifold and engine. usually yung stock air intake malapit sa engine and high up near the hood where the air is warmest.
you can extend the air intake by fabricating custom ducting and moving the opening away from the engine where the air is cooler. yung iba, pababa yung intake, bumper level na yung intake nila... but this isn't good for our floodspag extended yung intake like that, you'll notice a slight gain in power (depending on how restricted the stock intake was compared to the new setup) in any climate and ambient temperature.
Originally Posted by mbt
i see...thanks po sir mbt....hmm....so ano po kaya magandang gawin kung hindi down pipe ung gagawin ko?
i had once a crazy idea of re-routing one of the aircon hose to the
cai system...pwede kaya yun??
hehehe... ozcity try mo tapos post mo dito result sa engine response. :shock: :shock:
Guys wala ba tayong idea dyan para makakuha tayo ng cold air without the "flood" thing?Originally Posted by mbt
8) tanong lang po.....hindi po ba useless yung heatshield?....kasi kahit papano mainit parin sa loob ng engine compartment.....at the same time medjo restricted yung paghigop ng air...coz nakaharang yung heatshield compared to open cone intake.......
Yo coolrolla, there are heat shields that are not restrictiveOriginally Posted by coolrolla
Their purpose is to barricade the filter from the hot engine bay
A good example is the one made by K&N and not Simota. Saw it at Super Street mag and it isn't restrictive at all. It is actually good for filters situated at the back of the headlights
Try to look it up at K&N's website
Here's mine. It sucks outside air from behind the headlights but still above bumper line so there's less chance of water injestion. :mrgreen:
For some reason nawawala ang image... it was there the last time I was on line. Anyways, just click on any of my links... it's in there. :roll:Originally Posted by AC
