Results 1 to 15 of 15
    Feb 2005
    I just had my aircon system cleaned and refilled with freon. And while the aircon tech was going about the cleaning of my evap i asked him why is my aircon not that cold during noon time? he answered “its because these cars are not designed for tropical countries like the Philippines”. Okay, that got me pique a little bit so a follow up question is in order, I asked “what if we replace my evap with a laminated one? and may be we can also replace the condenser as well?” and he said “it will still be the same”. By this time I was screaming inside my head and wanted to argue with him but I decided not to and instead I’ll just ask you guys here if what he said have any incling of truthfullness.
    So, what do you think sirs, are laminated evaps and condensers not that effective as a replacement to the stock evaps and condensers? (as per the statement of my aircon mech, it’s just the same...)
    Jun 2005
    Malamang walang alam sa hvac system yan "technician". Natuto or nagmamarunong lang
    Sent from my MI MAX 2 using Tapatalk
    Feb 2009
    Quote Originally Posted by box_type View Post
    If your components are OEM they should be fine. There is no need to change them unless defective.
    If the cabin size changed, then the cooling load will have increased. Assuming you have the same interior volume and assuming the insulation the same your system should be adequate.
    The evap, condenser should be clean though. No paint over spray on the condenser.
    Change your A/C shop. That parts replacers does not understand how the A/C works. Maybe he doesn't use a thermometer and an accurate manifold gauge.
    Incompetence is evidenced by lack of understanding and resorting to excuses
    what is the coldest temperature in the morning vs noon time? (max settings)
    my sentra is factory serpentine.
    when it sprung a leak, my man replaced it with laminated, because it was much cheaper than serpentine, and because "i did not give specific-enough instructions". i had given him more than enough cash, as i already knew how much serpentine costs.
    hayun... the resulting cold was hilaw na hilaw. and the evaporator would ice up and block air flow. and this was during the colder -ber month.
    in exasperation, after two weeks, i replaced it with serpentine. the resulting cold was like factory brand new again!
    errr... what is your car, po?
    back in the day, nissans (i.e., my sentra) were given the reputation of having the coldest aircons around. but nowadays, it would seem that the competition has caught up.
    Mar 2018
    Nissan is very popular for their Calsonic AC system. Very efficient. I hope Nissan still uses Calsonic nowadays.
    Aug 2012
    lagi ko nga naririnig yan laminated evaporator pag may butas evaporator. sinabi pa ng mga aircon mechanic mas mahal yun laminated kasi mas malamig daw meron din daw local na evaporator makapal pero mabagal daw lumamig.
    my previous corolla (2nd hand) evaporator was replaced nalaman ko nalang nung hinde na lumalamig tapos yun evaporator maliit lang sa lagayan, sabi nung nag bukas ng aircon napalitan na daw (converted). buti nakuha sa linis yun hinde lumamig after a few year binenta ko na yun car. nakakatakot kasi baka dahil hinde oem yun evaporator masunog compressor.
    bakit ba kasi ang daming aircon shop sa aten lalo na yun tabi tabi lang na ang hilig i-magic ang evaporator and other parts... cost maybe a big factor.
    i always thought, serpentine was more expensive than laminated.
    but then, imported is usually more expensive than local.
    the usual problem with non-casa or non-oem, is that they are sometimes not a perfect fit.
    even a few mm is enough, for it not to fit right.
    i once tried to fit the cheaper replacement variety in my innova's rear evaporator. it was off by just less 5 mm, but it was enough for the thing not to sit right.
    May 2018
    Quote Originally Posted by 2lits17 View Post
    Years ago, I remember my dad once scolded yung mga mechanics namin at my uncle's talyer:
    "Dinesign ng engineer na Hapon yan tapos rere-medyohan nyo lang?!?!" Then everybody would laugh.
    It was really funny how they'd "MacGyver" (like the `90's TV show) repairs on the engines of the suking jeepney and taxis to keep them running. Naayos naman!
    Dec 2017
    I remember a few years ago when I had the radiator cleaned. Someone suggested that I replace it with a bigger one as the car will be more efficient. That is, the car will consume less fuel because of the better cooling capacity.
    Since I'm not an automotive expert, I verified to the guy that a bigger radiator will be heavier together with the added volume of water it will carry. He answered, "Yes it's heavier." That's the time I asked him how the car will be more fuel efficient with the added weight. He didn't answer and kept his mouth shut.
    Another thing, the guy who was cleaning the radiator kept on suggesting that I remove the thermostat. I couldn't think of way to say politely to leave it as is so I kept my mouth shut.
    May 2018
    Back in the day when cars weren't that complicated, a lot of folks did that kasi hot naman ang climate sa Pilipinas.
    People weren't too concerned about proper warm ups, basta di lang nag-ooverheat, ok na. Of course, this was decades ago, we know better now and cars have changed. Carryover lang yang suggestion nung aircon guy to the present day, pero obsolote na yung alam niya.
    Ngayon radiators are super thin (more efficient design perhaps) and made of plastic ata (lighter and cheaper). No more radiator overhauls. Replace the whole thing lang.
    Sep 2012
    What I learned from Ceejays when they repaired the ac of the old car
    1. The 134a gas is more effective in laminated type condenser and evaporator
    2. This means kung papalitan mo condenser mo ng laminated type, damay dapat mo na evaporator.
    3. Make sure that fan in front can blow enough air in between the fins of the condenser and radiator. If medyo alanganin, you can customise to add additional fans or replace fan motor with a faster one. Or else I demo nila palagi na laging binabasa condenser para lang lumamig [emoji28][emoji16]
    Aug 2012
    Quote Originally Posted by jodski View Post
    ah kaya pala ganun yun sinasabi nila during old days. pag summer daw at tirik ang araw basain lang yun condenser para lumamig and the exhaust fan really play a big role, naka ilan aircon shop ako hinde nila masolve yun issue na pag traffic and mainit mahina lamig ng aircon pero pag rekta takbo ok naman until i go to this one ac shop and told me change my exhaust fan, he compare my exhaust fan and the surplus fan, ang lakas nun surplus, after replacing it swabe na lamig kahit traffic pa.
    *Archerfish
    i also have the same scenario when my radiator top had cracks, palitan daw ng evercool kesa palitan yun top kasi plastic din daw yun at masisira in time. tsaka tanso daw yun hinde sasabog yun radiator pag nag overheat, but mas costly masabugan ng makina kesa radiator. and besides that car is almost 10 years old na and hinde ko alam anong maintenance ginawa ng may ari before baka hinde lang naalagaan at nawasa water lang nilalagay. so i decided to just overhaul/clean the radiator and palitan yun top plastic, it was running fine until i sold it.
    there is only one reason why there are plastic-tubbed radiators.
    "they're cheaper to manufacture."
    Mar 2004
    Weight is a primary factor ...
Laminated Evaporator and Condenser are they for real?
