Results 1 to 9 of 9
    Jan 2009
    For the Fit/Jazz/City platforms, the fuel tank is under the front seats. From the underside, it will be directly behind the engine.
    As Jick said... it may not be an actual leak but it is venting fumes into the cabin through the fuel pump/sending unit assembly gasket. The threaded lid is made of plastic and may have already cracked and loosened up due to wear.
    Fuel tank removed. The fuel pump/sending unit assembly is the white round thing at the top.
    EDIT: The 2nd pic is just to show where the fuel pump/sending unit assembly is, not to suggest that the fuel tank has to be removed. There should be an access panel from inside the cabin that will gain you access to the fuel pump/sending unit assembly. Judging by its placement and orientation, it will be somewhere under the center console.
    Mar 2004
    Thank you for your replies. No replacement has been made on the fuel system so far. I will have this checked ASAP. Will keep you posted.
    i suggest the ts remove the car lighter and keep in a far away place
    Jul 2011
    Quote Originally Posted by kinyo View Post
    Ganito po, punta ka sa isang well ventilated area, park nyo ang car nyo.
    1. start nyo ang engine make sure na ung air-intake selector ay naka re-circulate at magkulong po kayo sa loob
    1.a kung meron amoy, try no sundan kung saan lumulusot ung amoy
    1. b kung wala, go to next step
    2. i-on po nyo ang fan (ung aircon naka off), gamitin ang pang amoy kung meron amoy gas
    2.a kung meron, try no sundan kung saan lumulusot ung amoy
    2.b kung wala, go to next step
    3. i-on nyo na po ang aircon
    3.a kung meron, try no sundan kung saan lumulusot ung amoy
    3.b kung wala, go to next step
    Kung sa 1-3 walang amoy, posibility galing po sa ibang sasakyan ang naamoy nyo.
    next to try, you need a source of smell
    ulitin po ung above steps, with the smell being placed in front, right, rear and left side of your car.
    pero kung minsan meron amoy at minsan ay wala, possible po na nag o-open ung air-intake selector at kumukuha ng air sa labas.
    To prevent fogging up of the windshield, the air intake mode may change automatically to FRESH depending on the condition of the air conditioning system.
    Jul 2011
    Mar 2004
    Quote Originally Posted by Manilablock View Post
    Thank you for the reply. I had the fuel system checked thoroughly and the mechanic assured me that there is no sign of any leak whatsoever of the fuel system.
    I did also what *manilablock suggested and I observed the following:
    There is no smell when the aircon is turned off. The fumes come from the aircon vents but I can't trace the exit point. Yung air-intake for the re-circulation have been covered already by the aircon technician pero may naamoy pa rin ako na gas fumes which smells like coming from the smoke of other vehicles or coming from my own engine. What can I still do to address this?
Gasoline smell inside the cabin
