Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
    Jul 2013
    #21
    Auxillary fan is a primarily cooling system when the car is stationary.
    When your car start to move natural air-flow will be an additional scheme that will help cool down the condenser and radiator of your vehicle, and that will be less taxing to your cars battery. Its like having an imaginary fan blowing air in front of the car, so why add an additional fan in front that will block the natural air flow?
    Sent from my GT-P3110 using Tsikot Forums mobile app
    I understand this additional fan is for the condenser. I think the purpose is to get colder air from the aircon when the vehicle is stationary. One symptom of insufficient cooling of the condenser is that the air coming out of the aircon is not so cold when the vehicle is stationary but it will become cooler as it moves, and as you say, allow outside air to naturally cool the condenser.
    Aug 2014
    #22
    Quote Originally Posted by Lew_Alcindor View Post
    Yes, the main purpose is when during stationary, AC is unable to sustain the coldness inside the CAR that is why I decided to DIY the said setup, well, based on the old thread here provided me this idea.
    Putting, LAMP, thanks, I'll do that so I will be aware that its running.
    AIR FLOW, on the diagram, its going to the Condenser, so it should be correct already.
    Thanks for the replies.
    Dec 2009
    #23
    But the position of the fan now blocks the natural airflow, depending on the size of the fan will determine if this will be helpful or not in the long run
    This may help cool things up quickly while stationary, it then blocks natural airflow while on the move. If the additional auxillary fan induce air flow immediately after the aircon is switched on and and shuts off together with the aircon then that will shorten the life span of the battery
    Aug 2014
    #24
    The FAN does cover half of the condenser, the other half should accept the natural flow + the FAN blades are small, and though it can be turned on when AC is on or when compressor clutch engage, my intention is to switch ON only on stationary and turn it off when moving. I'll take the previous advise, to put pilot lamp so I can determine if its still turned on so I can switch off.
    Apr 2010
    #25
    wire the relay na whenever the compressor runs, the aux fan also turns on. can't see the need of a separate switch pa
    had this setup before and wala naman problems, just make sure that the alternator can compensate for the additional load
    Jul 2006
    #26
    Quote Originally Posted by aioshin View Post
    Tiga saan ka ba? Manila or province?
    Pag Manila, need mo aux fan. Most of the time traffic dito. .
    Pag province, no need.
    Aug 2014
    #27
    Tiga mindanao. Kaya palaging traffic dahil sa checkpoint. 😁
    Sent from a mobile device.
    #28
    i used to have a rear-wheel drive car. it got real hot in traffic.
    i asked my aircon man to remedy it. he put an aux fan in front of the radiator.
    after that, it was nice and very cold even in standstill, hot mid-day traffic! still as cold after the car moves.
    and no engine overheat issues.
    and the battery did not even notice.
    #29
    I am not savvy with electronic diagram but my suggestion is to make sure the direction of airflow is correct - towards the engine.
    i agree.
    and the solution may be quite easy. many of these are DC motors. however way they are installed, reversing the electrical connections, will reverse direction of blade rotation and the flow of air.
    Aug 2014
    #30
    i agree.
    yes, the connection can be reverse, and also the blades of the aux fan i put, should be observe properly because of its inclination or angle placement, you have to try reversing the blades to compare the output air, mine need to reverse the blade to get the maximum air.
    the FAN has 80 watts rating, so approx. 6 or 7 amps requirement, if im not wrong, hilander (my unit) has 40 or 50 amps alternator, so I think it can compensate the 7 amps. I plan to make it 2 to cover the whole condenser since currently it only cover the half, so 14 amps for the aux fan, turn it ON when needed, like traffic under the heat of the sun. turn it OFF at night.
    btw, got the FAN at 650 Pesos.
    Oct 2009
    #31
    naglagay din ako sa adventure ko ng ganyanng aux fan 600 kuha ko sa kingsport las pinyas.malaking tulong ang aux fan na yan lalo na dito sa manila na palaging ipit sa trapik.ung sa akin naman nilagyan ko nalang ng secret switch under the dash para pwede ko rin ipahinga kapag sa gabi na at walang trapik at kapag naka rekta ako sa express way..para hindi takaw sa baterya.ganda pa ng lamig ng AC
    Aug 2014
    #32
    Quote Originally Posted by jaypee10 View Post
    Epektibo nga talaga, mas malamig ang sasakyan kahit nakaparada nang matagal 12noon, On lang ang Aux FAN to support AC, turn off kung tumatakbo na. Dalawang FAN na nilagay ko sa harap ng condenser...
    Sep 2017
    #33
    Quote Originally Posted by jyg1995 View Post
    ok lang ba mag lagay ng 2 auxiliary fan??nag inquire ako sa Twins Auto Aircon sa valenzuela 4500 daw dalawang fan Sanden brand....pano ba yon??mag lalagay daw ng wire sa compressor para sabay pag nag automatic ung aircon...ok lang kaya yon???btw for 2012 suzuki apv pala......no issue naman sa sasakyan I just want to put some extra fan for my peace of mind na hindi sya mag-init.
    ...or mas ok kaya na sa Denso nalang sa ako mag palagay since denso namn ang aircon at cooling system ng apv????
    ..thanks
    for older cars i'd go for it, based on metro traffic it helps reduce stress
    #34
    Does it mean naka block po sa radiator airway ung aux fan? di naman tumataas water temp nyo lalo na sa highway/long drive? thanks.
    #35
    Quote Originally Posted by jao View Post
    the engine temp did not increase. i used a generic aux fan. it was turned on and off by the aircon's thermostat.
    see #28 in previous page.
Extra Auxiliary fan
