Page 1 of 2 12 LastLast
Results 1 to 20 of 35
    May 2012
    ok lang ba mag lagay ng 2 auxiliary fan??nag inquire ako sa Twins Auto Aircon sa valenzuela 4500 daw dalawang fan Sanden brand....pano ba yon??mag lalagay daw ng wire sa compressor para sabay pag nag automatic ung aircon...ok lang kaya yon???btw for 2012 suzuki apv pala......no issue naman sa sasakyan I just want to put some extra fan for my peace of mind na hindi sya mag-init.
    ...or mas ok kaya na sa Denso nalang sa ako mag palagay since denso namn ang aircon at cooling system ng apv????
    ..thanks
    Jul 2006
    I am not familiar with the APV, but I would assume that this is a front engined, rear wheel drive vehicle, correct? So apart from the engine driven fan, and the stock electric aux fan, you will still add two (2) fans more?
    Over kill na ata sa aux fans yan?
    May 2012
    It is a semi-bonneted van with a small 1.6L engine,,,,ung engine nya place under sa driver and passenger seats..pero ung radiator condenser nya nasa harap...ung radiator meron syang isang(1) dual speed na fan,when compressor engage the fan increased its speed...Im planning to put two(2) extra fan sa harap namn ng condenser kase may extra space pa between condenser and bumper..
    Jan 2009
    I think it's unnecessary. Also, seeing that it's a new car, you don't have to worry about overheating for as long as you keep cooling system properly maintained.
    I also think that you're likely to void the warranty if you do that.
    my opinion, is yes... makakatulong.
    but my question is, kakasya ba?
    baka lalo pang maging problema sa airflow ma ba-block lang ng fans ang airflow instead
    May 2012
    kasya naman po sya,malaki pa ung space nila.....nakita ko po ung pwedeng ilagay na aux fan ung sanden brand na 10 blades medyo di namn sya malaki kaya kasya talaga,,,,,,,,,,,,,,,,,,,,,,I think sir oj88 you have a point..to be honest I never saw my temperature needle go beyond its normal operating temperature..I will ask na lang sa suzuki kung pwede if ma void siguro hindi na,pero baka pwede din silang mag lagay pag pwede sakanila na lng ako mag papa install ng extra fan?
    Jul 2006
    Quote Originally Posted by jyg1995 View Post
    I see. So stock set-up is one big dual speed puller (higop) fan. IMHO, as long as you keep everything in tiptop shape, you would'nt need to worry about overheating something, suffice to say that it is also a new vehicle (almost).
    May 2012
    Quote Originally Posted by t2erns View Post
    isa din sya sa naisip ko...kase ung grill nya sa harap malaki kaso pag nilagyan na ng fan mahaharangan,,tapos ung stock fan nya ung hangin pa puntang radiator tas ung ikakabit papuntang condenser edi mag sasalubong ung hangin nila????
    May 2012
    yes sir isang dual speed na fan na naka tutok sa radiator,1yr 2mos ung car.....everything runs smooth and smells new pa din...wag na lng kaya??
    why mod your cooling system when your car is practically brand new and don't have issues. just save your money na lang para sa PMS nyan to keep it in tip top shape. sayang lang pera mo.
    May 2012
    Quote Originally Posted by blacksun25 View Post
    hehe Thanks for your input sir,,,my apv clocking near to 15k so change oil na uli.......I think I will invest more na lang sa tint nya papa full windshield ko na lang sya with v kool tint sa gold cars banawe....thanks po....APV VERY VERY VERY CHEAP TO MAINTAIN..HEHE thanks Suzuki
    Jan 2011
    i agree. your car is a result of long years of research, you dont need it. save your money for additional accessories that you want.
    Aug 2010
    pero, mukhang decided ka na magpalgay sir a.
    May 2012
    Quote Originally Posted by alfonsomiguel View Post
    slight hehe,,,,,,pero hindi na mag papa full body sticker na lng ako..
    Aug 2010
    oo sir, may point yung mga tsikoteers.
    Aug 2014
    Hi tsikoters, just added auxiliary sa hilander ko. Ito setup ko, umandar naman as how it should, ito diagram, pa advise na lang kung may mali...
    Sent from a mobile device.
    Jan 2011
    Quote Originally Posted by aioshin View Post
    Lagyan mo din sir ng pilot light, para alam mo kung merong power yung aux fan mo.
    Jul 2013
    I am not savvy with electronic diagram but my suggestion is to make sure the direction of airflow is correct - towards the engine.
    Dec 2009
    Auxillary fan is a primarily cooling system when the car is stationary.
    When your car start to move natural air-flow will be an additional scheme that will help cool down the condenser and radiator of your vehicle, and that will be less taxing to your cars battery. Its like having an imaginary fan blowing air in front of the car, so why add an additional fan in front that will block the natural air flow?
    Sent from my GT-P3110 using Tsikot Forums mobile app
Extra Auxiliary fan
