Forever a mystery on what the super formula is eh...
When i was searching for a lavramon service provider, i chanced upon this old article of Botchi Santos on PDI. He mentioned some coolants that are okay per his experience.
Keeping things cool underneath your hood | Inquirer Business
People debate about whether to use coolant at all aside from distilled water in your engine. Most experts agree that using a minimum of 20 percent coolant in your engine is necessary as this helps lubricate the moving parts of your water pump. Most manufacturers utilize a 50:50 coolant and distilled water mix from the factory, however. So stay in between the range of 20 and 50 percent coolant, with the rest being the purest, cleanest distilled water inside your engine and radiator. And let me reiterate to only use coolants from a known or trusted brand such as Motul’s Inugel, Toyota’s factory fill Red Coolant concentrate (popular with many amateur racers in the US even when used in different brands of cars), and Japanese performance brands like Billion’s Super Thermo line of coolants, ARC’s own line of coolants and locally, Caltex/Texaco’s Orange Coolant Concentrate.
3 months pa lang nagpalit ka na coolant?Originally Posted by fourtheboys96
Sent from my iPad using Forum Runner
Ang magandang coolant ung walang halong tubig, kasi ung tubig kahit distilled mababa ang boiling point at cause ng rust
Choosing The Right Coolant - Popular Mechanics
Water, with the proper anticorrosion additives, would make an adequate cooling medium for automotive engines. But it freezes, and boils over. Ethylene glycol, an alcohol, is added to extend the boiling and freezing points of the coolant. Why not run pure glycol, and get better freezing/boil-over protection? As you can see from the chart, pure ethylene glycol will freeze at essentially the same temperature as water. At concentrations higher then 70 percent or so, freeze protection is not very good. Also, ethylene glycol doesn't carry as much heat from the engine to the radiator as an equivalent amount of water, which can result in overheating. Stick with concentrations of 50 percent to 60 percent water/antifreeze.
Stick to OE recommendations.
Engines are not the same so does the coolant. Color of Dye may be the same but the acids used are not.
Here some good reading material from gates http://www.motor.com/magazine/pdfs/082012_08.pdf
The extended cooling system service intervals that became factory recommendations in the mid-1990s had a couple of objectives: reduced vehicle maintenance (which also equaled a money-saver for the motorist) and reduced environmental impact. The result has been successful—but with some unintended consequences, particularly for vehicle water pumps. Give motorists a seemingly logical reason not to have some maintenance performed and they won’t. The 100,000- and 150,000-mile service intervals have been so heavily promoted that motorists who drive 10,000 to 15,000 miles a year may never get the coolant exchanged (assuming they keep the car no more than 10 years). Of course, many of these recommendations come with a time specification—typically five years—but,not surprisingly, that part of the recommendation seems to get lost. A similar fate has befallen spark plugs. The carmakers have been promoting 100,000-to 120,000-mile spark plug replacement intervals, and the annual or even biannual “tuneup” has become history.
The 3000- to 4000-mile oil change interval seems to be surviving much better, however. With oil life indicators on the nstrument cluster, though, it’s probably just a matter of time before motorists begin to pick up on that, too, particularly with the promotion of socalled long-life oils.
Looks Can Be Deceiving
Aged coolant can have a deleterious effect on water pumps. Gates reports that 95% of failed water pumps were in cooling systems that never had a system flush. How could they tell? The failed water pump’s appearance. And the reason behind that appearance? The coolant is dirty, although “dirty” is not always that obvious. We’ve seen cars go a number of years with the coolant looking almost pristine, particularly in today’s all-aluminum engines. But a clean look doesn’t necessarily mean the coolant is really clean. Many contaminants don’t make the coolant look dirty. Sand and other abrasive debris particles, aluminum corrosion particles and mineral content in the water, to cite three examples, won’t be obvious.
The visually noticeable evidence is primarily on trucks, particularly trucks in the heavy-duty class and above, but also in light-duty models, which still have cast-iron blocks that may show signs of rust. A few trucks have aluminum block engines, but the majority of trucks (and many passenger cars) have cast-iron blocks. You find cast-iron blocks in such GM passenger cars as Chevy Impalas through 2011 (3.5 and 3.9L V6s); even the very new Chevy Volt 4-cylinders have cast-iron blocks. At Ford, the 4.6 and 5.4 V8s have cast-iron blocks, and so does the all-new 6.2 V8—all used in the F-series trucks. At Chrysler, until a Dodge/Ram truck or a Jeep got the new 3.6 V6, every 6-cylinder (3.3, 3.7, 3.8, 4.0) or V8 (4.7, 5.9) had a cast-iron block. The 5.7 and 6.1 HEMI V8s are still iron block. And lots of those Detroit Three vehicles and their cast-iron block engines are still on the road. So you can look for rust, although rust particles don’t always turn the coolant a shade of brown. And even when you see a brown particulate appearance in the coolant, it could be sealer, not rust particles.Yes, there was the well-known instance of rust accumulation in the radiator of GM pickups and SUVs with the 4.3 V6 and some V8s. But for the most part, the rust particles are less apparent in the coolant (particularly what’s visible in the reservoir), even if they restrict heat exchanger and engine cooling system passages and attack water pump seals. If you see a rust stain at any cooling system connection, or at the weep hole of the water pump, that’s a flashing light indicating coolant contamination. With aluminum blocks there isn’t much in the way of metallic particles that’s visible. “Dirt” also seems to be a bit of the luck of the draw. Some engine blocks are not cleaned of sand from the molds on the assembly line as well as others, and some heater cores and radiators are not, either, leaving residual flux that can result in corrosion. Furthermore, there’s the matter of how much coolant has leaked out, the need for periodic additions and the sources of the top-up fluids. (We’ll get to top-ups later.) The so-called normal amount of coolant loss depends on a number of things:
•Type of driving. If the vehicle runs hot because it’s driven a lot in heavy traffic, some coolant may blow out past the pressure cap relief valve and then the overflow tube. Not much can be done about this if the system’s cooling capacity is marginal. But if the system is running hot for any other reason, the problem is aggravated. Dirty coolant can add to the problem. So can electric fans that run slower than they should.
•Weak pressure cap valve. The pressure cap doesn’t have to be totally defective to cause a problem. Just because you can hear a whoosh as you turn the cap to release the pressure doesn’t mean the cap is good. A defective 17-psi cap valve may be popping open at just a few psi. The lowered pressure might be something you can feel as you turn the cap to release it—or maybe not. In any case, as standard operating procedure, the pressure cap should be tested with a pressure tester whenever the rest of the system is being tested.
•Complexity of the cooling system circuit. Many cooling systems have so many connections that even if they’re reasonably tight, they still can lose a fair amount of coolant. All antifreezes contain dye, so seepage from hose connections and radiator tubes usually is obvious. But if it isn’t, there are trace dyes that can make the leakage stand out. Problem: Many of the connections aren’t out in the open, and even with trace dye in the system, you have to be willing to remove covers and disconnect some parts to be able to see them all.
cont'd
too shortWhat About Top-Ups?
Whatever is in those top-ups has an effect on cooling system health because there’s a fair chance that if it’s antifreeze, it won’t be the OE coolant or a compatible formula. There are many formulas in use and, frankly, the charts we’ve seen have some inaccuracies, or they aren’t specific enough on when a coolant change was made. For example, Ford had been using two different coolants. One was the HOAT (hybrid organic acid technology), a low-silicate formula that has been sold as G-05 by Zerex and Custom Made by Havoline. The second is a low-phosphate formula
used by all Japanese and Korean makes, and available in the aftermarket as Zerex Asian long life/HOAT. However, Ford is in the middle of a OAT (no silicates, no phosphates; just one or two organic acid inhibitors), and it’s not compatible with either of the two previous formulas. Changes have been made midyear, so you have to check the specific vehicle data. And that’s not only on the late-models. A lot of pre-1995 General Motors cars used conventional American green antifreeze—which includes the old gold Prestone formula—with phosphates and silicates. The other Detroit makers stayed with green a while longer. The Prestone gold formula also changed just a few years ago, and if you read the fine print on the back of the current jug, you’ll see “2-ethylhexanoate,” the most widely used organic acid—no more phosphates or silicates. So the new shouldn’t even be mixed with the old. Does it really matter if you do a bit of mixing to get the system topped up? Well, it’s true that a coolant mixture—any mixture, including a lot of water—is better than running without enough coolant. But three common mixtures were tested by the prominent Amalga tech lab to the D4340 test, the industry’s basic test for aluminum corrosion (just 17% of the 50% antifreeze content was something other than the OE coolant). All resulted in “R” readings (a measurement of corrosion and deposits) above 3 to 4 (milligrams per square centimeter) in a one-week test—all off the chart. A reading of 1.0 is the specified maximum. Once you get above 3 or 4, explained Amalgatech’s Ed Eaton, any
differences don’t mean anything—the corrosion is excessive.
True Colors
One of the problems with identifying coolant, of course, is that you can’t rely on the color of the antifreeze. Chrysler’s OE antifreeze is a G-05 formula, but the dye is orange (like DexCool’s), even though the ingredients are different. However, the Fiat 500 contains orange dye and it’s a DexCool-compatible fluid, which means Chrysler is using two different formulas with the same color dye. Zerex’s Asian formula contains pink dye, but the Asian carmakers use a variety of dye colors, with only Toyota’s being pink (previously red). So you have to accept the possibility of changing the appearance of the OE dye when you top up. That’s okay—if you use the right formula. Another issue is the water. The OEM assembly line uses demineralized water, so the system starts out with the best. What’s used for top-ups? It should be distilled water, but more likely it’s from the shop faucet.
Contaminated coolant also is more prone to allowing water pump cavitation, in which imploding coolant bubbles pockmark the pump chamber, exposing metal to rust or corrosion. This eventually weakens output. A pure OAT antifreeze takes about 5000 miles to protect an exposed surface, so the pump could take a beating in the interim , and that especially includes a new pump coming in contact with contaminated coolant. Cavitation occurs most commonly in mountainous driving and other operation with measurable variable cooling system thermal loads. Sand was the No. 1 type of debris in one test performed by Gates, and that’s no surprise. Many engine blocks leave the cleaning process on the assembly line with more residual sand than others. But airborne abrasive debris of any kind can enter the water supply and end up in the cooling system, where it causes deterioration of the water pump seal, the primary cause of pump failure.
Materials used in the cooling system can become an issue as well. Some hose rubbers degrade internally more than others, although modern premiumbrand hoses perform much better. The familiar so-called hose squeeze tests identify an internally eroded hose. Also, excessive use of sealers becomes a problem, causing restrictions.
Water Pump Issues
Water pumps on many of today’s vehicles don’t show much leakage from the weep hole until pump wear is really severe. Because minor weeping often was misinterpreted, particularly by motorists who saw drops on the driveway floor from an idling engine, a well has been built into many pumps. Seepage collects in the well and evaporates from underhood heat, so although the weeping continues, it isn’t visible to the motorist. If there is noticeable dripping from one of these pumps, it’s likely an indication of real leakage. Although leakage is the No. 1 reason for water pump replacement (in twothirds of warranty submissions), other reasons can’t be ignored. If the pump bearing is noisy, the problem could be caused by leakage past the seal, but unless the weep hole is plugged, the noise is more likely caused by pulley misalignment. If pump output is weak, the root causes are either cavitation or severely contaminated coolant causing corrosion and erosion of a steel impeller. You’ll have to pull the pump in either case, after which the problem will be obvious. Whatever the issue, when a pump has to be replaced, the cooling system must be flushed. As we’ve pointed out many times—and as recently as in last year’s report—a flush & fill machine is the only practical way to get a significant percentage of the coolant replaced. But getting out the adhering debris is more difficult, and when a water pump has failed, you should go the extra mile to clean the system, which comes down to power-flushing. Many flush & fill machines do a good maintenance-level versio of that, but if a failed pump shows evidence of badly contaminated coolant, a heavy-duty power flush is a better approach.
Sa wheeler deelers po, ito ung youtube link
Wheeler Dealers, Edd China. Triumph TR6 Evans Waterless Engine Coolants Conversion - YouTube
sana maging available din ito sa pinas
If you're the type that is happy using well water in your radiators and your customers are happy not listening to good advice then you shouldn't have a stake in anything that improves efficiency and lowers operating costs. It ruins your business model after all.
Good hardware and "human software" are all part of a system.
Anhydrous coolants have benefits and the costs aren't so prohibitive but are normally overkill for most mainstream uses. If you have high mileage/high load/capacity vehicles, anhydrous coolants yield their returns but it isn't entirely just the coolant in this situation that requires replacement. There are some augmentations to your cooling subsystems required to get the full benefits from an anhydrous system.
And in case you're going to touch on this subject, you don't ever freaking top up an anhydrous coolant loop with water. Emphasis on never.
A radiator that needs a regular top up is defective by construction and/or doesn't come with the requisite information to benefit the end user.
madali lang yan
bili sa amazon
Amazon.com: evans coolant
padala b-bayan box
Buti pala wala pang nag tanong dito kung anong magandang coolant para sa VW Beetle or lumang Porsche niya. :D
There is a finite percentage tolerance of water for these solutions. If you place it in a contaminated loop it will degrade and you would have wasted your money on it.
If you've actually worked with anhydrous coolants you will need to be aware of the physical properties to prepare your vehicle or engine to get the maximum benefit from it.
Anhydrous coolants have much lower thermal conductivity than glycol/water mixtures but shine when high loads are placed on the engine. They do not conduct more heat, its just that it doesn't evaporate like water does.
This coolant isn't certified for track use, its composition is majority glycol and a proprietary formula. So if it spills on the track it will be slippery.
Again, if you don't drive your vehicle hard, or you don't have very heavy loads, the OEM long-life coolants will serve you well.
On the upside though you don't need to worry about cavitation, corrosion, and clogging. These are the immediate benefits of anhydrous coolants. For those alone it should be a good investment if you plan to keep your car for a long time. And yes, your old beetle and porsche's and vintage collectibles will be a good example of a proper application.
That's why Leno uses them because the solution doesn't evaporate or permeate when he leaves them in his collection of cars. Most of which he doesn't drive regularly.
lowslowbenz may want to look at this to alleviate his routine ritual.
If you have leaks -plug them. This has nothing to do with your radiator or coolant.
