Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    Feb 2004
    My Corolla is a 1996 Toyota Corolla Gli, 1.6L, Manual Transmission, EFI.
    I have been having problems with my A/C system. There appears to be no pattern on when this is occuring. Whether it's a cold or hot day, fan in the highest or lowest setting, temperature control in max or min setting etc., the A/C just erratically quits working. I've noticed that sometimes, the compressor clutch engages and sometimes, it doesn't. So I did the following to trace the possible cause of the issue:
    -There is enough refrigerant. Minimal bubbles on filter drier sight glass.
    -Clutch is functional. If I directly energize it or short the relay contacts, the clutch would engage and AC works.
    - Compressor Relay has been replaced (just in case). No AC related blown fuses found.
    - Checked the voltage across the relays. Whenever the issue happens, no 12V DC is being read.
    - Disconnecting or shorting the pressure sensor does not help in engaging the compressor.
    - Checked if the temperature setting (variable resistor) is functional. I got good readings from min to max setting.
    What happens is, when I turn on the A/C, only the blower turns on. I also noticed that erratically, the engine's idling would go up but the compressor isn't simultaneously engaging. If I disconnect the A/C "blackbox" (under the dashboard), idling would get back to normal.
    I am now suspecting that probably something is wrong with the "black box" that serves as the A/C controller. No observable burnt components there so I just cleaned the connectors with a contact cleaner. Until now, I am still getting the erratic A/C performance. What could be going on? How can I know if the black box is kaput? How about the thermostat? Could it be the culprit? What other sensors play a part in turning the compressor on? How do I proceed and troubleshoot?
    Salamat sa mga makakatulong. Pinost ko na rin sa http://www.allexperts.com yan. Di pa nakakasagot yung mga Kano. Pinoy diskarte pa din inaasahan ko.
    Dec 2003
    magnetic clutch ng compressor?
    used to have the problem, bumitaw, engage ang magnetic clutch kaya up and down idling din
    Feb 2004
    Thanks for the quick reply Mojo.
    Pero tingin ko hindi clutch e. Nag rekta na ako ng switch sa relay papunta sa magnetic clutch. Tuloy tuloy kapit ng clutch at lumalamig ang aircon. Kaso, walang idle up na nangyayari kaya bumababa yung RPM hanggang 700, minsan nga namamatayan pa ako ng makina.
    Saan ba magaling na A/C shop na reliable at mapagkakatiwalaan? Ano kaya problema ng AC ko?
    Tnx
    Aug 2003
    better visit Mang Mario (search for directions here). He's VERY well recommended, I've also tried his service myself.
    i would think there's something wrong with the thing which controls your A/C relay. Kasi you say the idle doesn't go up when the A/C engages? the idle-up is implemented by the idle air control valve (since GLI car mo, it uses an ECU/computer box).
    i think the "black box" inside your dash IS THE ECU, not just for the A/C. mga 6000 din yun surplus but it's main job is to control the engine and if your engine is running, it's doubtful na may sira yun...
    Feb 2004
    Galing na din ako dun. Recommendation nya, convert na lang daw to conventional na thermostat controlled. Bale may ikakabit sya na standalone thermostat at yun yung mago-on off ng compressor. Gagana yun kung sa gagana, kaso di yun yung best solution kasi wala nang idle-up compensation na mangyayari. Bypassed na din yung temp control setting sa dashboard plus yung iba pang sensors (like hi press) na binabasa din ng AC box.
    So you lose performance and protection. Naku, sakit sa ulo to. May iba pa bang shops na recommended kayo? San ba makakabili ng surplus na AC controller. Ala sa banawe e.
    Feb 2005
    Looks like an electrical problem dude. What aircon do you have? Is it a Denso? If it is, I have an electrical diagram. We can trace it from there. I don't recommend altering your electrical system. Like what you said, it is not the best solution. Worse, it's gonna give headaches to next person whose gonna fix your car.
    Feb 2004
    Zeagle,
    Yes, I think it is a denso. can you forward me the diagram please? fr33m5n*yahoo.com
    Thanks!
    Feb 2005
    Quote Originally Posted by xfreemanx
    Zeagle,
    Thanks!
    Sorry dude I don't have a scanner. Daan ka na lang sa office.
    Jan 2003
    di ba sanden ang oem a/c ng gli?
    try to open the black box of the aircon, baka meron lang busted relay sa loob nyan hehe..
    yung liteace namin eh relay lang sira sa loob ng black box, pagka-replace ng relay eh back to normal na ulit ang aircon... pero the black box of the corolla might be different hehe..
    Feb 2006
    wala na bang remedyo ang sirain at mahinang aircon ng mga rolla?
    Aug 2005
    saking corolla busted fuse lang sa engine glove box or nsa dashboard panel.. yung lang .. or maybe something short sa aircon connections.. check all connections even the drivers dashboard panels as ive said
    Aug 2005
    ei.. Ill add up.. I think its the actuator.. just check.. when actuator got busted the unstable idle appears..
    Why don't you bring it to a Denso Service Center? I suppose they would know how to diagnose the situation.
    Aug 2005
    I
    It seems to me that in a given time some parts get stock up, bearings or inside the compressor. there's a signal to compressor to engage it thats why engine idling goes up meaning additional load to the engine and yet it can not rotate the compressor so no cooling happened.....May be...
    Quote Originally Posted by finchy18
    had the same problem before, tagal ding na solve. Pinalitan ko ng surplus yung idle up, cost me P600 pesos including installation sa evangelista, daming shop dun.
    Aug 2005
    Sir, Eto pa isa, walang supply sa relay, so electrical problem, but is it the output of the relay has no 12V DC or the input? pag yong output ng relay ang walang supply eh tumbok mo na problem.. it's the relay, but kung sa input pa lang ay wala ng supply its may be the thermostat or where's the thermostat get its supply, maybe pressure switch din naka open..
    Aug 2005
    hindin naman dali masira yung relay eh..
    Reading from your problem,and as far as my experience on same problem ,you have a problem with the current signal of your Electronic Thermostat which sense and controls the temperature in the evaporator. You need to buy a new electronic thermostat in order to normalize the erratic flow of signal to the compressor. Trust me this will work
    Nov 2007
    huh? matagal na atang post ito...pero kung merong badget palitan mo na stabiliser ng thermostat..pag low sa budget pwede na itong convert sa ordinary thermostat...basta alam mo..ala namang prob so far mgakinabitan ko.
Corolla GLI Aircon Problem
