Results 11 to 20 of 26
- Feb 2006
- 18
Toyota is my choice
- Aug 2005
- 2,063
March 20th, 2006 10:51 AM #12saking corolla busted fuse lang sa engine glove box or nsa dashboard panel.. yung lang .. or maybe something short sa aircon connections.. check all connections even the drivers dashboard panels as ive said
..Last edited by finchy18; March 20th, 2006 at 10:56 AM.
Toyota is my choice
- Aug 2005
- 2,063
March 20th, 2006 10:53 AM #13ei.. Ill add up.. I think its the actuator.. just check.. when actuator got busted the unstable idle appears..
March 20th, 2006 11:57 AM #14
Why don't you bring it to a Denso Service Center? I suppose they would know how to diagnose the situation.
March 20th, 2006 10:11 PM #15Originally Posted by xfreemanx
March 20th, 2006 10:19 PM #16Originally Posted by finchy18
March 20th, 2006 10:44 PM #17Originally Posted by xfreemanx
Toyota is my choice
- Aug 2005
- 2,063
- Nov 2010
- 1
November 11th, 2010 08:42 PM #19Reading from your problem,and as far as my experience on same problem ,you have a problem with the current signal of your Electronic Thermostat which sense and controls the temperature in the evaporator. You need to buy a new electronic thermostat in order to normalize the erratic flow of signal to the compressor. Trust me this will work
- Nov 2007
- 164
November 15th, 2010 07:38 PM #20huh? matagal na atang post ito...pero kung merong badget palitan mo na stabiliser ng thermostat..pag low sa budget pwede na itong convert sa ordinary thermostat...basta alam mo..ala namang prob so far mgakinabitan ko.
Thank you!
