My Corolla is a 1996 Toyota Corolla Gli, 1.6L, Manual Transmission, EFI.
I have been having problems with my A/C system. There appears to be no pattern on when this is occuring. Whether it's a cold or hot day, fan in the highest or lowest setting, temperature control in max or min setting etc., the A/C just erratically quits working. I've noticed that sometimes, the compressor clutch engages and sometimes, it doesn't. So I did the following to trace the possible cause of the issue:
-There is enough refrigerant. Minimal bubbles on filter drier sight glass.
-Clutch is functional. If I directly energize it or short the relay contacts, the clutch would engage and AC works.
- Compressor Relay has been replaced (just in case). No AC related blown fuses found.
- Checked the voltage across the relays. Whenever the issue happens, no 12V DC is being read.
- Disconnecting or shorting the pressure sensor does not help in engaging the compressor.
- Checked if the temperature setting (variable resistor) is functional. I got good readings from min to max setting.
What happens is, when I turn on the A/C, only the blower turns on. I also noticed that erratically, the engine's idling would go up but the compressor isn't simultaneously engaging. If I disconnect the A/C "blackbox" (under the dashboard), idling would get back to normal.
I am now suspecting that probably something is wrong with the "black box" that serves as the A/C controller. No observable burnt components there so I just cleaned the connectors with a contact cleaner. Until now, I am still getting the erratic A/C performance. What could be going on? How can I know if the black box is kaput? How about the thermostat? Could it be the culprit? What other sensors play a part in turning the compressor on? How do I proceed and troubleshoot?
Salamat sa mga makakatulong. Pinost ko na rin sa http://www.allexperts.com yan. Di pa nakakasagot yung mga Kano. Pinoy diskarte pa din inaasahan ko.
Naku, sakit sa ulo to. May iba pa bang shops na recommended kayo? San ba makakabili ng surplus na AC controller. Ala sa banawe e.
