Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
    #21
    The TS's concern is higher than his "used to" temperature which is still normal as per the manufacturer, therefore to them is not a concern.
    but why did you recommend tampering with the EGR in entry #18 above?
    you were answering his concern, were you not?
    otherwise, you could have simply said, "that's still acceptable, i.e., normal as per manufacturer", and put to rest TS's concerns.
    Feb 2009
    #22
    Yes doc este atty. technically it is not tampering but making the EGR more effective but not a necessity in this case
    #23
    "...tampering.." ... "making more effective"..
    counselor, i rest my case.
    but never mind this legalese..
    my question remains, is there a downside in "making the EGR more effective..." ? ..because i do not know the answer.. but i suspect it adds to the pollution..
cooling the radiator/engine by pouring water on the radiator itself (coils/pipes)
