use coolant for its anti rust properties. not for the cooler engine temps.
open up the civic and the lancer and i'm pretty sure which one will have cleaner water passages.
water: heat transfer capability means more heat can be absorbed by the water away from the engine but water has a less boiling point (100 deg C) compared to coolant. so if na-reach na ng tubig ung boiling point nya especially in hot and long driving, there's a lot of steam generation trying to escape out of the radiator (overheat)..
coolant naman, although less ang heat transfer capability nya, they have high boiling point naman (130 deg C). may anti-rust and lubricating property pa..
Peeps singit lang na OT.
Pwede ba halo ang coolant additive sa water methanol injection? Antirust?
Totoo ba pwede wiper washer fluid dito? Is it economical?
Where in Manila can people buy methanol in bulk for this application?
+1
The Lancer's water pump failure could be due to any number of things not related to the use or non-use of coolant.
I'm really pissed with one of our former drivers... he made it a habit of topping off the Crosswind with tap water. Now we have a problem!
After 10,000 kms of use with tap water, the coolant bottle is full of rust and the radiator looks like it's full of mud... and it's losing water every few hundred kilometers... I'm thinking quite a few of the internal water passages are clogged by now.
While you can run a car for quite a long while on water only, it's a huge compromise. The Civic might be able to get away with it, due to its well designed water passages and an engine that doesn't need as much cooling as other 1.6s and which can survive overheating better than most... (I'm still amazed by the tiny radiator in that thing) ...but it's not going to be a very happy engine by the time you need to overhaul it.
ask lang po mga bro, may evrerest 2007 model ako ,ang coolant niya ay kulay green ngayon ang nirekomenda ng ford dealer ay Shell Coolguard OAT na kulay pula,pwede ko ba e halo o ilagay sa reservoir ng radiator? maraming salamat po!
medyo mahaba but it should answer a lot of questions.
http://www.eetcorp.com/antifreeze/antifreeze-faq.htm
Last edited by userfriendly; October 10th, 2007 at 12:09 AM. Reason: changed entire post
^ Thanks doon sa link.
So ang mali timpla pala ng coolant eh pwede makasira ng water pump.
Ilan kms or months dapat palitan ang coolant?
Pag may coolant na ba hindi ba nagbabawas sa radiator. Kasi sa tubig nagbabawas after 2 weeks.
usually ilan years bago ma-overhaul radiator?
Ano yung ok dito sa pinas na pre-mixed coolant?
Kung marami na scales, rust eh pwede pa ba ipalinis ang radiator para mawala?
Thanks
