Results 1 to 5 of 5
- Dec 2008
- 33
May 8th, 2010 03:30 PM #1mga bosing tulong naman po...ano po kaya ang cause ng leak sa pressure switch ng filter dryer? pinalitan na pero wala paring lamig...pag nasira ba ang pressure switch kailangan palitan na rin yung filter dryer at expansion valve?
May 8th, 2010 04:46 PM #2
if it had leaked, obviously the refrigerant pressure would be less. the air conditioner will not perform at its optimum or never operate at all. if the system had been leaking and been "topped off" a couple of times, chances are the amount of moisture introduced into the system would be enough to saturate the receiver/dryer. if you are not skimping on the expense and don't want to second guess as to when it will not work properly, it is wise to have the system serviced, expansion valve replaced, receiver/dryer replaced and the compressor drained and changed
May 8th, 2010 08:46 PM #3
- Dec 2008
- 33
- Jun 2007
- 22
July 3rd, 2013 05:52 PM #5cause of busted pressure switch, malutong na ung plastic, palit mo ung original huwag ung replacement mura lang naman
