Results 1 to 5 of 5
    Dec 2008
    mga bosing tulong naman po...ano po kaya ang cause ng leak sa pressure switch ng filter dryer? pinalitan na pero wala paring lamig...pag nasira ba ang pressure switch kailangan palitan na rin yung filter dryer at expansion valve?
    Feb 2009
    Quote Originally Posted by icedrop View Post
    if it had leaked, obviously the refrigerant pressure would be less. the air conditioner will not perform at its optimum or never operate at all. if the system had been leaking and been "topped off" a couple of times, chances are the amount of moisture introduced into the system would be enough to saturate the receiver/dryer. if you are not skimping on the expense and don't want to second guess as to when it will not work properly, it is wise to have the system serviced, expansion valve replaced, receiver/dryer replaced and the compressor drained and changed
    Feb 2009
    correction:
    expansion valve replaced, receiver/dryer replaced and the compressor drained and the oil changed
    Dec 2008
    thank you sir for the advice. god bless!
    Jun 2007
    cause of busted pressure switch, malutong na ung plastic, palit mo ung original huwag ung replacement mura lang naman
cause of busted pressure switch?
