Results 141 to 150 of 273
- Jul 2016
- 9
July 2nd, 2016 05:19 PM #141Mga sir ask ko lang kung anng problema sa ac ng xtrail ko..everytime na i on ko sya malamig yung buga pero after few minutes hihina na yung buga ng aircon..plan ko tomorrow ipalinis..salamat and godbless to all..
Sent from my SM-G355H using Tsikot Forums mobile app
July 2nd, 2016 05:45 PM #142
Malamig initially then hindi namemaintain. It could be the condenser fan. Usually when you start your vehicle the condenser is cool. But once the ac is working the heat absorbed by the condenser must be dissipated by the fan/s.
If you start your vehicle. Switch on the ac to maximum, the fans should be spinning.
Age of your vehicle?
- Mar 2014
- 901
July 2nd, 2016 07:19 PM #143My advice, dalhin mo sa isang Aircon Shop, have it checked by their a/c technician. Libre naman ang check up at estimate. A good a/c technician can determine what is faulty with your Auto A/C System just initially looking and observing in a test gauge. Then, if you decide to have it service by them, i-observe mo nalang ang trabaho nila kung maayos at maingat sa paggawa. At kung umokey na A/C system ng car mo. Give us some feedback, so we may all know(tsikoteer members), if the A/C Shop is good in their service.
Starmobile Up+
- Jul 2016
- 9
July 2nd, 2016 08:12 PM #144Thank you sir sa advice..ill let you know tomorrow kng anng result..last thing sir..my idea ba kyo sa service ng frigid zone kamuning branch..im planning kc na dalhin ko dun tomorrow ung sasakyan..thanks a lot
- Mar 2014
- 901
July 2nd, 2016 10:43 PM #145To be honest with you, I don't have any experiences with their services. But somehow I read somewhere here in the forum in some of our members praises their shop services in auto a/c. Open ba shop nila even on sundays?
Anyway, just give us some feedback of the results.
Starmobile Up+
- 49,426
July 2nd, 2016 11:18 PM #146if your evaporator is not factory anymore, my guess is, they put in the in-correct one. (the correct one costs 2-3 times the cost of the incorrect one.)
i had similar problem with my sentra. the original evaporator sprung a leak, and someone had it replaced.
at first, malamig. then, the air flow would get less and less.
i traced it to incorrect evaporator. the wrong one they put in, would ice up after a few minutes and prevent air from flowing thru.
putting in the correct one, solved the problem.
puede rin, low on freon ang aircon.
- Jul 2016
- 9
July 5th, 2016 03:08 PM #147Thank you sir sa advice..ipapacheck ko nalang ung evaporator ko..last sunday pinalagyan ko ng freon ung sasakyan kc sabi ng technician unti nalang dw ung laman it was my third time na magpalagay ng freon since april..possible my leak ba ung hose or dahil lang sa sobrang init ng panahon..thanks
- Jun 2008
- 1,740
July 5th, 2016 07:25 PM #148May leak ang system mo. Ipa comprehensive leak test mo.
Sent from my Lenovo A7000-a using Tsikot Forums mobile app
- Jul 2016
- 5
July 5th, 2016 07:53 PM #149Hi patulong naman po ako sa problema sa AC ng civic 07 ko.
Pinagawa ko sya last week tapos may nakitang leak. Nilagyan ulit ng freon saka inayos yung part na may leak at nalinis na din yung parts ng AC. Nung dinrive ko pauwi okay naman, malamig na ulet.
Kaso after 2 days, nawawala ulit yung lamig lalo na pag long drive. Nakita eh yung condenser fan ko di umiikot, pag tinuktok saka lang iikot kaya pinalitan yung motor. Kaya bumili ako ng replacement para sa motor. Okay na ulit sya nung dinrive ko pauwi, kaso after 2 days ulet, nawawala na naman lamig.
Pag cold start lang malamig tapos after siguro 2 hours of continuous driving mawawala na. Pag pinatay ko AC for 10 minutes tapos binuksan ko ulet lalamig ulet sya kaso siguro for 2 minutes lang tapos magiging stale ulet yung hangin, amoy kulob pa yung nalabas. Ano kaya problema ng AC ko? Bukas ibabalik ko dun sa pinagpagawaan ko kaso wala na ko tiwala dun eh lol
- Mar 2014
- 901
July 5th, 2016 08:24 PM #150Naayos yun leak. Nilinis yung A/C, alin dun? Evaporator? Kung ok pa Thermal Expansion Valve (TXV) sa evaporator. Bago ba kargahan ng freon uli, nai-vacuum ba nila ang A/C system mo kahit 30mins.? Basta nag-open ng system sa A/C, it needs to be vacuum, to suck out moisture and air. Kung hindi, hindi lalamig o sasablay talaga ang lamig. Kasi yun minsan ang iniikot ng compressor kapag umikot yung part ng air sa system line at hindi freon. And kadalasan rin kailangan magpalit talaga ng receiver drier.
Starmobile Up+
I went with it not because of it's offroad features. I like Subaru in general and love EyeSight....
2018 Subaru XV - needs urgent tire replacement
