if your evaporator is not factory anymore, my guess is, they put in the in-correct one. (the correct one costs 2-3 times the cost of the incorrect one.)
i had similar problem with my sentra. the original evaporator sprung a leak, and someone had it replaced.
at first, malamig. then, the air flow would get less and less.
i traced it to incorrect evaporator. the wrong one they put in, would ice up after a few minutes and prevent air from flowing thru.
putting in the correct one, solved the problem.
puede rin, low on freon ang aircon.
Thank you sir sa advice..ipapacheck ko nalang ung evaporator ko..last sunday pinalagyan ko ng freon ung sasakyan kc sabi ng technician unti nalang dw ung laman it was my third time na magpalagay ng freon since april..possible my leak ba ung hose or dahil lang sa sobrang init ng panahon..thanks
Sent from my SM-G355H using Tsikot Forums mobile app
