Results 1 to 4 of 4
- May 2008
- 4
May 3rd, 2008 04:37 AM #1my a/c's thermostat switch is located underneath the glove compartment. analog yata yun? how do i set the thermostat settings? set nung a/c technician slightly turned to the right lang. parang nasa 1 or 2 lang. can i set to mga 7-8 (meaning ikot ko pa pa-kanan hanggang 7-8 level) or mas maganda na naka-steady na lang sa 1-2? ano po ba ang mas maganda? nasa 1-2 level or kung nasa bandang 7-8 or max? thanks.
May 5th, 2008 09:21 AM #2
it would depend on the temperature inside and outside the car.
my thermo switch is just set at around 6-7. hindi ko pa naisagad yun more than that.
pag taglamig, i usually set it at around 5 (yung gitna).
- Oct 2006
- 148
May 5th, 2008 02:57 PM #3Make sure lang na hindi magyeyelo yung hose mo papuntang evaporator pag inadjust mo sya kasi pwedeng makasira yun ng compressor mo.
May 5th, 2008 04:00 PM #4
gandang question ito ngayong 2008 summer mine is between 1/3 and 3/4 setting.
as above, if you want to go OEM-style, get a "spare tyre lock". but i use an ordinary cheap...
