Results 1 to 10 of 19
- Oct 2004
- 45
May 23rd, 2006 10:38 PM #1My aircon compressor needs replacement (mazda 323 sedan) , what brand do you recommend? I passby at banawe a week ago they recommend 4 brands:
1. panasonic p14,000.00
2. denso p 9,000.00
3. sanden 507 p 8,000.00
4. sanden 507 p 6,000.00
May 23rd, 2006 10:44 PM #2
wala bang compatibility pagdating sa a/c compressor and the a/c's other components?
- Oct 2004
- 45
May 23rd, 2006 10:49 PM #3I don't realy know, if compatibility is also a requirement in replacing aircon compressor.
May 23rd, 2006 11:19 PM #4
Whats the stock compresor of Mazda ba? Well for me, better to stick with an OEM compressor (not saying na bumili ka sa casa).. an aircon specialist told me that if you'll variate an OE compressor, it might be possible for some vehicles or yours, that their tubings might won't fit from a different compressor. Though it's possible, but you'll compromise w/ an additional expense to change those thingys (tubings etc.).
My compressor is deteriorating too, so in the future i'm opting to change from OE Sanden to Denso (surplus only).. kaso yun nga lang sabe saken na baka o hindi talaga magkatugma kung ibang brand, atsaka dagdag gastos pa sa ibang parts na papalitan. So di bale na lang siguro.. hehe...just my 5 cents. :D
May 23rd, 2006 11:48 PM #5
Check the OEM brand first. That'll make it easier.
For compressors which I am free to choose the brand (e.g. converting the MB a/c or fitting a/c to a/c-less car), SANDEN is usually what we use. They're cheap and very much available. Good serviceability, too.
- May 2006
- 6
May 24th, 2006 09:41 AM #6Originally Posted by rayban7g
In short, choose the same brand and model that is currently attached to your engine. Saves you a lot of trouble and time. May hurt you upfront with the cost, but the savings in time and trouble is well worth it.
May 24th, 2006 07:00 PM #9
as what the other posters said use the OEM wala kang magiging problem sa mounting and alignment. alignment is very important to prevent belt damage and noise
Toyota is my choice
- Aug 2005
- 2,063
May 24th, 2006 07:22 PM #10First to hear a panasonic aircon.. I strongly suggest when replacing stock compressor it should be the same brand.. while replacing to other brand and if your condenser and evaporator is still good dont replace it. If it is Sanden go for Sanden.
If that's the case, then hindi rin pala lahat ng nakaka-afford sa kanila ay hindi frugal mag-isip...
2021 Toyota Land Cruiser LC300
