Results 21 to 30 of 75
- May 2017
- 19
May 2nd, 2017 04:29 PM #21Thanks for the info! My car is scheduled at Nissan Ortigas tomorrow; I will keep you posted.
Sent from my SM-A510Y using Tsikot Forums mobile app
- May 2017
- 19
May 4th, 2017 01:34 PM #22Update: Nissan Ortigas checked the AC yesterday and gave these recommendations: Replace Expansion Valve Assembly (Part # 92200M, cost = 5,800 + labor), and for further "observation" daw ang Compressor. They tried to charge me 2K for diagnostics, but ended up paying 1,300 because I complained!
Question - will replacing the Expansion Valve fix and lower the pressure? It is currently 80, and believe that the correct pressure is only around 40.
Isabay na daw ang complete A/C cleaning when they install the Expansion Valve (need to order from Nissan Japan and will take 45 days to deliver). All in all, I am looking at around 15k if I listen to these geniuses!
I'm guessing they want me to the spend money, before the actually replace the Compressor, which is still under warranty. I will take it to another Nissan dealer for a second opinion.
Please advise, thanks.
- May 2017
- 19
May 4th, 2017 01:40 PM #23I'm guessing they want me to spend more money, before they actually replace the Compressor, which is still under warranty! Sorry for the typo above, I am just really annoyed right now.
- Aug 2016
- 22
May 4th, 2017 02:11 PM #24Grabe pa rin pala service ng Nissan Gallery Ortigas. Ang daming bad reviews sa kanila. Go to Nissan Q.Ave or Nissan Sucat. I'm very sure, maayos service nila dun. Makikita mo pa habang ginagalaw ang sasakyan mo.
- Jul 2016
- 939
May 4th, 2017 02:44 PM #25Paano ba warranty ng Nissan sa AC? Sa hyundai ko dati wala ako binayaran when I claimed for a compressor and exp. valve replacement under warranty.
I suggest email mo concern with Nissan PH.
Contact Us | Nissan Philippines
- 54,211
May 4th, 2017 08:03 PM #26
- May 2017
- 19
May 8th, 2017 04:51 PM #27Compressor is under warranty, but they are not touching it until the Expansion Valve is replaced (not covered under warranty)! In any event, I emailed Nissan Corporate and every Nissan company that has an email address, and got a response from Nissan Corporate PH. They are currently coordinating with Nissan Ortigas, and should hear back from them soon! I will keep you posted, thanks.
May 9th, 2017 12:23 PM #28
Expansion valve is part of the AC system as a whole. Without it, your AC will not work properly.
Galing naman nila mag reason out sa yo eh contradicting naman explanation.
Read po the fine print. Pag naka lagay AC System eh di kasama yan sa coverage ng warranty.
- May 2017
- 19
May 26th, 2017 12:29 PM #29Finally got my car back yesterday! Expansion Valve Assembly and Compressor have been replaced, plus front wheel alignment and 10 liters of gas C/O Nissan Ortigas. They even refunded the Diagnostic fee they charged me when I first took my car for check-up. I dealt with NPI corporate customer service mostly (through emails) and did not have to wait more than 45 days (as initially suggested by Nissan Ortigas) to get my car fixed. 50K PMS is done as well. The car is running like new again. Thank you all for your comments.
June 12th, 2017 07:50 AM #30
last saturday, nagpunta ako sa isang car aircon shop near Buendia Makati. yung aircon ng kotse ko hindi na malamig even at night time (worst sa tanghali, nagbubuga ng mainit na hangin). I suspect initially na wala nang freon kasi nung nacheck ko yung tube niya, mainit. pero when I checked na sa shop, meron pa siyang freon and the mechanic told me na kailangan nila mag check ng leaks (which I presume na babaklasin ang parts)
pero naisip ko rin yung compressor (baka ito yung reason na hindi lumalamig ang aircon ng car ko)
do I need to replace the compressor na, or ipapaubaya ko na sa mechanic yung repair/leak test?
car: Mazda 323
What do you guys think of this alleged defect of the 2017 a/t models? ...
The Toyota Fortuner has landed (fortuner pics at...
