Results 11 to 15 of 15
February 16th, 2012 10:11 PM #11
February 17th, 2012 11:31 AM #12
That right they said 120k, they must be crazy because I could get a full used engine for that much.
February 17th, 2012 01:07 PM #13
It probably is a quote for a full a/c system rebuild from the Hyundai casa. Taga talaga. A full rebuild (replace everything from compressors, driers, evaporators, condensers, expansion valves, aux fans and a/c hose lines) will probably cost you less than 40k outside for a dual system.
If the compressor really needs to be replaced, I suggest to get a brand new one since surplus units are a hit and miss thing. Consumables that need to be replaced are refrigerants, oil and filter/driers. The rest can stay as long as there are no punctures/leaks in the system.
- Feb 2012
- 4
February 17th, 2012 04:38 PM #14I repaired my Aircon Unit last year.
Not sure if they repair the compressor.. maybe u can check with the company..
February 18th, 2012 03:58 PM #15
bro, starex madali lang i repair yan original na left hand drive naman yan, depende sa sira..
compressor halla 10k puwede mo rin pa convert yan sa sanden
condenser 5k
evaporator 4k laminated
expansion valve 1,500 front & rear 2pcs.
drier aluminum 600
others O-ring, Oil, Hoses, cleaning chemical, 3k
di naman siguro papalitan lahat yan, kung papalitan lahat nasa 24k lang.
plus labor fee.. masyadong mahal sa 120K
high idle RPM at engine start
