Results 451 to 458 of 458
November 18th, 2022 11:57 AM #451
- Jan 2008
- 4,726
November 18th, 2022 01:47 PM #452
November 18th, 2022 03:49 PM #453
Standard ba ung <10c para masabi na ayos? Hanggang 16c lang kasi ang thermostat ng Ford Territory ko and after that LO na nakalagay. Kaya lang pag tinapat ko kamay ko sa vent hindi sya kasing lamig ng 9 year old Civic ko.
- Jan 2008
- 4,726
November 19th, 2022 12:49 AM #45416c is cabin temp setting.. iba yung air temp sa vent mismo.. ideal is around 10deg para ramdam mo yung "16 deg" na setting..
To test, lagay mo sa vent yan thermometer.. at max fan, lowest temp setting it should read around 10 deg or less..
- Jan 2008
- 4,726
November 19th, 2022 12:56 AM #455Lagay mo sa Lo.. max fan, car should be in shade ha.. place the thermometer sa vent.. pasok yung probe sa loob ng vent.. then observe mo how low it can go..
Also open the hood, observe mo kung naka engage yung compressor.. may cars kasi na kahit lagay mo sa Lo, once na reach yung naka program na cooling coil temp sa ECM, mag cutoff na agad yan..
November 19th, 2022 09:50 AM #456
Wow thanks for the procedure mhen!
Usually gano katagal bago ma achieve ang stable max reading?
Tapos, I also have to take the temp while compressor is engaged di ba, dahil mabilis na tataas ang reading once na bumitaw ito, right?
November 19th, 2022 10:29 AM #457
Ang usually na ECM ang nag control ng pag cycle eh yun mga meron heater dahil yun thermostat eh sa pag blend lang ng cold and hot air. Pag nag adjust ka ng thermostat yun flap lang na control to open for hot air to come in and blend with cold air or close the flap altogether eitheir for cold or hot air.
Unlike pag walang heater directly mo ma-control yun pag cycle ng compressor thru sa thermostat.
At least that’s what I understand it.
Sent from my iPhone using TapatalkLast edited by shadow; November 19th, 2022 at 10:32 AM.
November 19th, 2022 10:41 AM #458
Oo nga, and naalala ko lang, same sa house AC ata, pag naka full low, hindi na mag off ang compressor.
Xiaomi E-Car
