Results 161 to 170 of 220
November 21st, 2018 12:13 PM #161
Share ko lang...nagpagawa ako ng aircon kay Mang Danny over the weekend. Satisfied customer here
nauubos ang freon ng car ko and hindi ma trace ng aircon repair shop near our place, 2 months na ako pabalik balik
sa kanila. after the fourth freon top up, dinala ko sa ibang aircon repair shop...ang quote sa akin almost 20k !!!
i texted and booked with Danny (got his celno from this thread), we met early morning sa Seaoil. he found the leak, had the hose replaced, and did a retest. he worked on it for about 3 hours and charged me 2,850 pesos. i will observe in the next 2 to 3 weeks, pag hindi nagbago ang lamig then the leak has been fixed.
highly recommended, you just need to text him to set an appointment, nakikipuwesto lang sya sa Seaoil and he pays the gasoline station cashier a certain amount and they let him use a corner near the toilets.
hope this helps.
January 21st, 2019 06:58 AM #162
My batman vios had a scandalous squealing noise from a cold start or a stop lalo na kapag may a/c (so I drove around without an a/c). I tried the test suggested on YouTube to spray water on the belt to see if it goes away and it wouldn't. From reading related threads, it could be from different things (belt, bearings, pulley, magnetic clutch, urgh) and because I don't know anything about cars, I knew I had to go to a trusted a/c mechanic. I "booked an appointment" with Mang Danny and when I got there, there was already another customer (the girl on the picture) but there's a spot reserved for me. He checked my car right away, tightened the serpentine belt, checked the A/C and showed me (from the meter he was using) that it is fine. Pabugahan ko lang daw ng tubig sa car wash yung front grill para luminis. He didn't charge me anything and won't accept even a tip, maybe because to him he didn't really do anything. I hope I'm not advocating that people abuse him because "he doesn't charge" for little things. I'm only saying this is one honest and helpful guy. [emoji106]
Also thanks to travajante and dreamur.
January 21st, 2019 08:55 AM #164
January 21st, 2019 09:18 AM #165
January 21st, 2019 12:30 PM #166
- May 2010
- 186
February 11th, 2019 05:43 PM #167Nag palinis ako sa kanya non sabado. Mahina na yun lamig ng aircon pero fully functional pa (walang break down kahit tanghaling tapat or El Nino pa kaya ang decide ako palinisan sa kanya. Tinawagan ko sabado umaga at 1pm pumunta ako sa SeaOil. Tapos na yun isang customer niya pagdating ko so ako na agad!
Unit ko is Innova Gas 2009 M/T 121K+ km. First time malinisan ang aircon. Alaga lang sa filter palit once a year linis every 3mos. Hindi binaklas yun dashboard . Glove box at yun plastic lang sa manibela yun tinggal at nadinukot na yun fan at evaporator. Sa likod na aircon naman ay binaklas yun right side plastic "wall" (gilid ng last row na upuan) pati yun right side part ng rear bumper para madukot yun evaporator at aircon assembly don.
Wala naman tagas or langis sa 2 evaporators (front rear). Kadiri lang yun evaporator kasi parang malapot na plema yun dumi . Binugahan na lang ng tubig galing sa pressure washer. Hindi na nilagyan ng solution agent kasi baka masira daw ng maaga yun evaporators (may mga tama na kunti mga fins pero ok pa daw). Nag top-up din ng 3 silicon oil/gel sa fan at palit filter drier. 3 hours yun gawa 3 sila.
Cost:
* Labor + Filter Drier - 4,500.00
* 3 pcs Silicon Oil - 180.00 (60 x 3)
* 1 liter coolang (natapon kasi non tinggal nila radiator hose para madukot yun fan) - 202.00
* Tip - bigyan ko na lang daw isa nyan mekaniko na nagkalas ng fan
Total - 4,680 + 202.00 + Tip.
Balik lamig ulit aircon ng trusted innova ko.
Salamat!
- Feb 2017
- 164
May 3rd, 2019 09:06 PM #168Hi,
Is his shop still in Seaoil along Pasig Blvd. area? Need to contact him and have my aircon checked.
Sent from my ONEPLUS A5010 using Tapatalk
May 4th, 2019 10:32 AM #170
Xiaomi E-Car
