Results 41 to 50 of 52
- Dec 2011
- 2
December 2nd, 2011 11:11 PM #41Gasgas na nga yung tanong na overheating but still the problem has no exact solution but rather the problem is still there...................and overheating causes a lot of trouble.......
December 15th, 2011 01:40 AM #43
Mga sir/mam, pa advise na din kasi exact na nangyayari (rise in temperature almost sa red line na and pag stop ko to check kumukulo nga water sa reservoir) sa ride ko ngaun ito pag tumatakbo ng 90-120kph for about 10mins or more.
Nae-experience ko lang ito pag nag byahe kami sa SLEX or NLEX. Pero pag city driving nman at nagbu-burst speed (100-120) ako like sa edsa or C5, totally walang problema nman related to overheating.
What could be the problem or culprit that causes the problem??
December 15th, 2011 09:10 AM #44
December 15th, 2011 09:08 PM #45
December 16th, 2011 12:35 AM #46
a thermostat that fails to open ("stuck in the closed position") will overheat the engine no matter what the engine speed is....
a missing thermostat (i.e. removed) will overheat the engine on low speed runs (traffic) and overcool on open highway runs....
symptom is overheating at open highway and prolonged high engine speeds......
if all of the items stated by sir vinj checks out okay, check your belt, belt tension, water pump, and then your hoses especially the lower one.....usually, the upper hose is the first to go. check them both anyway.
experienced the same problem and it turned out that the lower hose is collapsing at high engine speeds because it (hose) was soft.
water pump creates partial vacuum at the suction side (lower hose).
hth
- Apr 2010
- 71
January 4th, 2012 09:23 PM #47
- May 2011
- 1
February 29th, 2012 02:23 PM #48Ako rin po. Kelangan magpa-check ng overheating na Altis 2005 A/T 1.8 model. Kelangan malapit sa Ortigas Center kasi baka di umabot sa shop. Salamat sa advice. Where can I find a reliable shop in the Ortigas Center-Shaw Boulevard area?
- Jul 2011
- 262
March 22nd, 2012 11:20 AM #50
^Just recently, our old lancer itlog had a bit of overheating problems. I did several coolant flush, it didn't work. Tried the Lav'ra mon service, it did clean the engine block but didn't remove the clogged radiator fins.
Tried to bring it to a radiator shop. The mechanic manually opened the radiator and de-clogged the fins. It was full of rust. Now no more overheat. The overhaul only costs 600.
Xiaomi E-Car
