Results 11 to 14 of 14
- Jun 2013
- 8
June 25th, 2013 01:08 PM #12
start with removing your fuel filter and clean or change it.Kundi man tap the filter to dislodge
any debris for a full minute vigorously with the handle of a screw driver perhaps.
If it starts after this.
Mag pa service ka, change all fluids and filters. Retighten everything..
Para sigurado ka na hindi ikaw ang may sira.
And list all the service done on a small notebook.
Baka sala salabat na mga wiring din ng kotse mo dahil hindi na se service ng maayos.
Have a real certified auto technician see your car. If not ikaw ang may problem.
See it as a triangle, the car needs a new battery,
or the battery needs a new car,
or the car needs a new owner.
Most of the time, it is just dirty fuel.
Good morning nga pala.Last edited by mark_t; June 25th, 2013 at 01:24 PM.
- Apr 2010
- 19
June 25th, 2013 11:27 PM #13Share ko experience ko sa Mazda 323 1300cc ko kapag nakapark ako naka On ang AC after 15mins kung patayin ko makina drain na ang battery hirap na mag start. New battery new alternator 50amperes. Pero kung hindi ako gumagamit ng AC no problem kaya ang ginawa ko check ko battery voltage by means of multimeter at ammeter habang naka On ang AC natuklasan ko na yon pala unti-unti na dedrain ang battery hindi kaya ma recover ng alternator ang ginagamit na kuryente. Kaya ginagawa ko kapag malapit na sa bahay pinapatay ko na ang AC ayon ok na. Need to change a higher alternator amperage. Isa pa kung maayos ang starter mo baka wala sa tamang ignition timing. Ang isa pang problema try to remove the air filter check if theres a very tiny jet flow of fuel when you pump the accelarator kapag kasi wala jet flow wala siya supply ng fuel hard to start siya umaasa lang sa suction ng fuel.
- Jun 2013
- 8
June 26th, 2013 01:11 PM #14thanks sir vootlog sa pag share.itry ko na patayin ang aircon pag pauwi na.dati kasi hindi naman kasi sya ganun.
Xiaomi E-Car
