Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
    #21
    Quote Originally Posted by Renzokuken View Post
    Nung dinrive ko kahapon biglang wala nang lamig yung aircon.
    Last time I had the aircon checked was January 2019 pa.
    Wala naman akong ibang naexperience na issues recently.
    Sent from my CLT-L29 using Tsikot Forums mobile app
    Sira na ba talaga yun auxialliary fan? Makikita mo naman eh
    #22
    Salamat.
    I asked about the compressor. Ok naman daw. Although may disclaimer sya na mas makikita daw pag nirepair na. Siguro sinasabi nila pag binuksan na yung aircon system.
    if you doubt the aircon shop,
    go to one or two other shops, for their opinion.
    things to check before considering opening up the system:
    1. freon level.
    2. electrical issues. aux fan, aux fan relay.
    3. is the compressor turning? magnetic clutch and its relay.
    is your car overheating?
    automotive aircon technology is usually straightforward. no secrets.
    May 2012
    #23
    Yes hindi sya naikot.
    #24
    Yun lang muna papalitan mo then go from there.
    May 2012
    #25
    1. freon level.
    Yup thats the plan, to get 2nd or even 3rd opinion
    No, car is not overheating.
    At least the temp gauge has been up to 8 or 9 bars lang naman (middle of gauge)
    Thank you
    Jan 2004
    #26
    Yup biglang walang lamig. Wala naman ako napansing leak and wala din naman nakita yung nagestimate. Hindi ako naoverheat. I think for radiator sya - eto yung visible yung elisi pag inangat mo ang hood tama ba?
    minsan hindi talaga makikita ang leak pag visual inspection lang, dapat nag check ng level ng freon, pag nag babawas, may leak yan somewhere
    May 2012
    #27
    Thanks
    Sige pacheck at tanong ko din ito
    #28
    happened to me twice bigla walang lamig pero nag engage ang compressor.
    1st time, ang naging prob is mahina or hindi na umiikot ung fan sa condenser. nung sinilip ko hindi nga umiikot, tinry ko katukin ung fan motor at nun lang siya gumana. so un pina replace ko ung fan motor sa condenser.
    2nd time, used the car for a week, napansin ko parang hilaw ung lamig then sa mga sumunod na araw unti unting nawawala ung lamig gang sa nawala ng tuluyan. pagdala ko sa ac shop, leak test. nakita ang leak sa may discharge hose. un lang ang naging sira.
    medyo mahal po ang quote sa inyo. try niyo po sa ac shops na iba. hindi bale dumayo basta surebol ang gawa.
    hope this helps.
Aircon Repair Estimate
