Results 11 to 17 of 17
March 14th, 2005 03:49 PM #11
pwede din sa cooling coil..
yan ang problem ng escape ko ngayon..may leak.
pero okay lang, underwarranty..hintayin ko lang dumating ung part.
March 14th, 2005 10:53 PM #12
Kapag cooling coil ang nag-leak, hindi na talaga lalamig from the start.
March 15th, 2005 06:01 AM #13Originally Posted by OTEP
March 15th, 2005 09:01 AM #14
Kasi you claim the problem is caused then the aircon is run for a while while in the sun. Try mo to eliminate one variable which is the sun.
Try running the a/c at night, while the vehicle is parked. Tignan mo kung magloloko pa din.
Make sure the engine is running also.
- Oct 2004
- 27
March 15th, 2005 10:28 AM #15carlgirl dalin mo kay mang Mario cgurado solve problema mo sa aircon sa 146 Fort Santiago St. Bago Bantay Q,C. Mura sila sumingil hndi ka nila tatagain tama si OTEP nagyeyelo ung evaporator mo pag kc na black ng yelo ung evaporator mo walang mahihigop na hangin ung blower mawawala ung aircon pag pinahinga mo ung aircon ibig sabihin natunaw na ung yelo gagana na ulit ung aircon. Pag ganyan ung sakit ng aircon madumi o sira na ung termostat.
March 16th, 2005 03:43 AM #16Originally Posted by OTEP
March 16th, 2005 03:44 AM #17Originally Posted by rbortega1981
As long as it is valid, bring a printed copy. Then, they will ask you to use one of the PCs there...
