Results 1 to 10 of 49
September 28th, 2007 04:50 PM #1
how do you get rid of this bad odor coming from the car's air-con? it's quite irritating because the car is still new and it emitts this particular smell (like cloth that didn't dry well)..the smell stays for only about 20 sec from air-con start up. I don't know where it comes from. Wala naman sumakay/sumasakay/pinapasakay na taong mabaho dun hehehehe
I need your help!
Bka kasi may alam kayo na solution para ndi ko na sya dalhin sa dealer. Thanks!!
September 28th, 2007 05:00 PM #2
Turn off the A/C but not the blower. Leave the blower on for a two to three minutes in high setting before turning the system off.
September 28th, 2007 05:05 PM #3
That's probably coming from the moisture that accumulates near the AC system air inlet.
September 29th, 2007 05:25 AM #5
ilang taon na yung sasakyan? you might want to have the A/C system cleaned.
September 29th, 2007 08:19 AM #6
check the pollen filter, most modern cars have one...
replace if possible...
Tsikot Member Rank 4
- Jul 2003
- 1,082
September 29th, 2007 12:27 PM #7if this is an FD civic, ganyan daw talaga. 2 friends ko na naka FD yan ang problema.
October 1st, 2007 05:17 AM #8
October 1st, 2007 09:38 AM #9
October 1st, 2007 10:05 AM #10
Ganyan din unit ko wayback in ’01 kabago-bago amoy pawis ang singaw ng vent!
Asked myself, ganito ba talaga pag diesel? Because it was my first diesel ride. What I did is I make it a point to turn off the a/c thermostat on-off switch first for a few minutes before shutting down the fan and engine. Eventually nawala ang amoy panis na pawis na akala ko yung mga mech sa casa hehehe.
Design & Dimensions: Exterior Refresh> Builds on current Kodo design with sharper, more...
2026 Mazda CX-5
