Results 1 to 10 of 49
September 28th, 2007 04:50 PM #1
how do you get rid of this bad odor coming from the car's air-con? it's quite irritating because the car is still new and it emitts this particular smell (like cloth that didn't dry well)..the smell stays for only about 20 sec from air-con start up. I don't know where it comes from. Wala naman sumakay/sumasakay/pinapasakay na taong mabaho dun hehehehe I need your help! Bka kasi may alam kayo na solution para ndi ko na sya dalhin sa dealer. Thanks!!
September 28th, 2007 05:00 PM #2
Turn off the A/C but not the blower. Leave the blower on for a two to three minutes in high setting before turning the system off.
September 28th, 2007 05:05 PM #3
That's probably coming from the moisture that accumulates near the AC system air inlet.
September 29th, 2007 05:25 AM #5
ilang taon na yung sasakyan? you might want to have the A/C system cleaned.
September 29th, 2007 08:19 AM #6
check the pollen filter, most modern cars have one...
replace if possible...
Tsikot Member Rank 4
- Jul 2003
- 1,082
September 29th, 2007 12:27 PM #7if this is an FD civic, ganyan daw talaga. 2 friends ko na naka FD yan ang problema.
October 1st, 2007 05:17 AM #8
October 1st, 2007 09:38 AM #9
October 1st, 2007 10:05 AM #10
Ganyan din unit ko wayback in ’01 kabago-bago amoy pawis ang singaw ng vent! Asked myself, ganito ba talaga pag diesel? Because it was my first diesel ride. What I did is I make it a point to turn off the a/c thermostat on-off switch first for a few minutes before shutting down the fan and engine. Eventually nawala ang amoy panis na pawis na akala ko yung mga mech sa casa hehehe.
In my car idle on coldstart was 2k high need 2 to3 mins to be restarted the engine to get the...
high idle RPM at engine start
