Results 151 to 160 of 174
April 17th, 2015 06:54 PM #151
May 2nd, 2016 01:26 AM #152
Mga sir anu sa tingin nyo kung gagawing 3 condenser yung van ko may ilalamig pa kaya?
- Apr 2012
- 3
May 13th, 2016 01:49 PM #153pa help naman po, Isuzu trooper bighorn model 99 ung akin, 4jg2.
napalitan ko na po ung
receiver drier
Zexel compressor
expansion valve
front evaporator
cleaned AC system
pero hilaw pa din po lamig nung auto ko. kahit linisin ung condenser.
kelangan ko po bang palitan na din pati condenser? thnks
- May 2016
- 5
May 13th, 2016 02:24 PM #155
- Sep 2008
- 587
May 13th, 2016 02:42 PM #156Assuming that all your parts that was replaced are all in good condition, meaning walang factory defects, and both high and low side lines are in optimum range, I would think that the problem maybe in your freon. Madami kasing freon ngayon na below standard, ergo, hilaw ang lamig ng aircon
May 17th, 2016 03:05 PM #157
May 17th, 2016 05:59 PM #158
- Sep 2008
- 587
May 25th, 2016 01:14 PM #159Maybe you are referring to the evaporator which is located inside and behind the dashboard, it comes in two kinds, the laminated and the serpentine. Although it is true that laminated ones give out colder air than the serpentine ones, I suggest you first determine if all other components are functioning well and without leaks using the aircon gauges before you presume that you might have to replace the evaporator.
- Jun 2008
- 1,741
May 25th, 2016 02:12 PM #160Bago palitan ang condenser bakit di subukan linisin muna then add auxiliary fan para lumamig ang condenser. A surplus aux fan will do.
Sent from my Lenovo A7000-a using Tsikot Forums mobile app
Xiaomi E-Car
