Results 91 to 100 of 174
May 25th, 2014 10:25 AM #91
b0y37,
Baka mahina na din ang rad fan nyo sir or pwede din na madumi ang condenser. Pabugahan nyo ng pressure washer or kahit hose habang naka hi pressure sya. pag lumamig, either madumi sya or mahina ang fan.
Since adventure yan, pa check nyo din yung fan clutch at aux fan.Last edited by non-vtec; May 25th, 2014 at 10:28 AM.
May 25th, 2014 01:33 PM #92
May 25th, 2014 07:07 PM #93
^Madami factors yan sir. Yung mga unang labas ng toyota uses serpentine type na cooling coil. Which has limited rows compared to the laminated coils with several rows. 2nd is your compressor. If your van came with a since AC, then nilagyan ng dual AC without upgrading the compressor, di rin kakayanin. I also doubt those locally manufactured/fabricated equipment's build quality. Pwede din kasi na design fault ng manufacturer. Kaya usually in later models ng toyota, made for tropical weather na talaga yung AC.
Going back, yung pagbuga ng tubig sa condenser will temporarily solve the high pressure situation since it will help the aux fan in converting gas to liquid. this process is interrupted by a weak aux fan or clogged condenser fins.
May 26th, 2014 12:09 AM #95
I think yung Sanden 508 is good for dual AC. Yung drier kasi needs to be replaced periodically. Specially if nasiraan ka ng compressor. It works by removing moisture and metal particles. Sakin, I replace it every 3 years.
Check the cold line if malamig and nagpapawis. It should be freezing cold, pero not to the point na nagyeyelo. If not, pwedeng kulang sa freon.
The best way pa din talaga is to hook it up sa AC gauge to know the actual health of your compressor.
- Aug 2012
- 2,767
May 26th, 2014 10:18 AM #96compared to residential aircon, ilan HP ang aircon for car, van, and bus?
May 26th, 2014 08:37 PM #97
May 26th, 2014 09:23 PM #98
Pwede din ibalik... Pero dapat malinis yung tangke na paglalagyan ng freon mo..
Sent from my C2305 using Tsikot Forums mobile app
May 26th, 2014 09:26 PM #99
May 27th, 2014 12:43 AM #100
Depende sa shop sir if equipped ng refrigerant recovery machine. Ideally palitan nyo na lang freon ng Eufron para sure na malamig.
OT:
My Cefiro has sprung a leak somewhere. Hindi mahanap sa mga lines sa engine bay. Hassle kasi just had it cleaned last June. Sayang din kasi it can go as low a 3 degrees sa vents. Gastos na naman.
high idle RPM at engine start
