Results 1 to 10 of 22
- Sep 2008
- 21
June 19th, 2009 06:09 PM #1mga gurus.. im newbee d2 a forum na ito and very happy that i learned a lot from experts and people who share their knowledge regarding car maintenance and trouble shooting..my ride is 99 el lancer and im having trouble with my aircon.minsan pag nag drive ako going to work nawawala yung lamig. dinala ko na sa aircon shop and they clean and charge the freon..pero ganun pa rin nawawala yung lamig but bumabalik ulit pag nag direretso ulit yung andar..binalik ko sa shop sabi nila me mulawag na wiring sa me wiring they put some contact cleaner on it but still same problem..any comment from you guys.. in my assestment di kaya dahil sa mahina yung charge ng alternator?? i have digital voltage reading..when reading comes to 13.81V dun naglokoko yung a/c.kailangan bng i overhaul ko yung alternator?? i think my battery is ok because off engine voltage reading is 12.35V ..or thermostat?? how much po kung papalitan ng thermostat??looking forward for comments. thanks in advance!! more power to tsikot
June 19th, 2009 06:14 PM #2
Solution: change A/C shop.
Your problem might be a slow leak somewhere in your A/C system. The shop will have to take apart your A/C system and do a leak test on every part.
June 19th, 2009 07:14 PM #3
try mo muna palitan ng manua thermostat mura lang naman ito cost 350petot lang,, baka nag mamalfunction na ang thermostat mo kaya minsan me lamig minsan blower lang,, try mo obserbahan pag namatay ang thermostat i mean compresor ilang minutes bago sya bumuhay ulit? or baka kailangan mo pa tapakan ang gas pedal para bumukas ulit ang compresor
June 19th, 2009 10:05 PM #4
check mo rin yung magnetic coil ba yun ng compressor
yan kasi naging problem ko dati nung nagloko rin a/c ng corolla namin dati
THE AUTO SPECIALIST
- Mar 2006
- 607
June 20th, 2009 09:43 PM #5kailangan jan diagnose muna ng AC shop para sure . mahirap ang baka sakali . tama si GH palit ng AC shop
- Aug 2009
- 31
August 27th, 2009 02:48 AM #6[quote=eiganram;1262052]mga gurus.. im newbee d2 a forum na ito and very happy that i learned a lot from experts and people who share their knowledge regarding car maintenance and trouble shooting..my ride is 99 el lancer and im having trouble with my aircon.minsan pag nag drive ako going to work nawawala yung lamig. dinala ko na sa aircon shop and they clean and charge the freon..pero ganun pa rin nawawala yung lamig but bumabalik ulit pag nag direretso ulit yung andar..binalik ko sa shop sabi nila me mulawag na wiring sa me wiring they put some contact cleaner on it but still same problem..any comment from you guys.. in my assestment di kaya dahil sa mahina yung charge ng alternator?? i have digital voltage reading..when reading comes to 13.81V dun naglokoko yung a/c.kailangan bng i overhaul ko yung alternator?? i think my battery is ok because off engine voltage reading is 12.35V ..or thermostat?? how much po kung papalitan ng thermostat??looking forward for comments. thanks in advance!! more power to tsikot[/quote
maaring di masyado na vacuum ang system nung linisin ito,kaya may natirang hangin na sumasabay sa freon, na pag nagcondense ang freon magco-condense din ang air sa loob ng system at pag dating sa expansion valve pag nag evaporate ang freon para lumamig di na nagagawang mag evaporate ng air na naging moisture magyeyelo na sya dun nagiging dahilang ng pag bara sa expansion valve.ito ang dahilan kung bakit nawawala ang lamig at kapag natunaw na naman yung moisture na naging ice sa loob ng exp.valve magsisimula na uli sya lumamig so on and so port
papalitan mo filter drier mo at expansion valve at pa vacuum mo ang system ng matagal para masiguro na moisture free ang system mo
August 27th, 2009 03:58 AM #7
THE AUTO SPECIALIST
- Mar 2006
- 607
August 27th, 2009 08:49 AM #8
August 27th, 2009 10:45 AM #9
August 27th, 2009 10:51 AM #10
New app update for Gcash. It locks the Gcash account to the particular device you are using so you...
National ID Law
