Results 11 to 20 of 27
- Feb 2013
- 32
December 1st, 2013 04:23 PM #11Thanks for all the replies! I got my unit back. Confirmed - they replaced the fusebox for an estimated cost of PhP 11k. All other parts were working just fine. Took me around 4-5 days to get it back from the casa.
- Aug 2010
- 86
December 3rd, 2013 01:29 PM #12
- Feb 2013
- 32
June 10th, 2016 10:01 PM #13Actually, parang napreempt ko ata sa casa.
However, recently, I brought it to the casa for a repair that is non-AC related. Casa told me na they flushed some stuff/dirt daw from the AC (kasi may naipon na daw na maraming dumi?).
Pagkabalik nung car from the repair, it seemed that the fan was weak and the AC was okay. After sometime, humihina yung fan although okay pa rin naman yung lamig. Nagtry ako lakasan yung fan (kasi mainit nga yung weather before) para lang lumamig tapos after sometime, yung AC naman yung humihina.
Ang problem ngayon naman, wala nang lamig from the AC (wala yung usual "activating sound") tapos yung fan naman mas malakas as compared to before pero mainit nga lang (kasi wala nang AC).
I contacted the Casa and they're recommending na for general cleaning lang daw yun (which costs 10k).
What do you think is the problem again here? May nakita akong Youtube video: 2 2 - 2 8 Honda CRV Air condition Problems - Recall for AC Clutch - ( Service Advisory Notice ) - YouTube pero hindi ko alam kung legit or valid pa yung recall dito sa Pinas.
Can it be the fusebox again? Saang shop kaya na reliable pwedeng ipacheck/clean/repair? I read the recent posts/replies re: Mang Mario so meron pa kayang mga possible alternatives sa shop niya?
Thanks in advance!
June 10th, 2016 11:33 PM #14
If you're in the metro I highly recommend Ceejay's in Las Pinas City. Specialty talaga nila ang car AC. I just had mine repaired last Fri and couldn't be more happy. Ayos pa sa customer service. Look them up sa FB. Btw mga satisfied customers nila ang gumawa ng FB page nila.[emoji2] Good luck!
P.S. they offer a discount when you mention you're a member at the Tsikot forum.
- Feb 2013
- 32
June 11th, 2016 02:06 AM #15
June 11th, 2016 09:26 AM #16
Ang 2nd gen crv may defective ang ac compressor nyan.nagkakaso na ang honda dati dahil sa "black death".isearch nyo at makikita nyo ang daming nagkaproblema jan.tuwing ginagamit ang AC tuloy tuloy naman ang pagpump nya ng black sooth o dumi sa buong AC system.at pag dumating na yung time minsan titigil nalang o minsan sumasabog din yung compressor.that time kailangan na palitan bung system kasi contaminated na sya at hindi na kaya ng flush.
Sent from my E6853 using Tsikot Forums mobile app
- Feb 2013
- 32
June 28th, 2016 12:28 AM #17Thanks. Luckily, the expansion valve and receiver drier just needs to be replaced. Cheaper as compared to having the compressor replaced. Malamig na talaga yung AC, as in super lamig na parang bago. However, I'm getting water leaks though under the compartment of the passenger side na for rechecking ulit.
June 30th, 2016 02:44 PM #18
Try mo bumili ng AC duct cleaner yung nagfo foam.try mo maghanap nung nakalata na may kasamang hose.isaksak mo mula sa ilalim ng sasakyan sa may drain hose.as far as it can go.tapos idischarge mo yung laman.wait for few minutes tapos i on mo na AC.baka barado lang yung drain pipe nyan
- Feb 2013
- 32
January 27th, 2019 04:38 PM #19
- Feb 2013
- 32
January 27th, 2019 04:39 PM #20Humina na yung lamig ng AC ulit - hindi umaabot sa 2nd row ng car.
May pinapalinis ba dapat regularly or may kailangan irefill?
Thanks
For the most part, he's ok. Except for the way he tests the film strengths of motor oils using the...
Liquid tire sealant
