Results 71 to 77 of 77
July 9th, 2008 08:03 PM #71
Wow! You have such good memory. I had the supports replaced as you and the others have advised but I haven't had the power steering done yet (I already bought the kit). I don't know/can't decide where to bring the car for the power steering repair kasi.
alwayz_yummy I just bought a new compressor January of this year.Last edited by _Cathy_; July 9th, 2008 at 08:10 PM.
THE AUTO SPECIALIST
- Mar 2006
- 607
July 10th, 2008 06:57 AM #72this time find an A/C tech to properly diagnose your A/C problem . i would suggest that your system has to be recovered in order to determine the right amount of refrigerant in there . it should be around 1.60 lbs.
if it's overcharged, the compressor will work harder and eventually fails . the low side gauge should read at 35- 40 psi * idle , and the high side gauge should be 175-250 psi . the condenser fan should be working .
from the gauges alone , the A/C tech will be able to pinpoint the rootcause of all your troubles.
September 5th, 2009 03:34 AM #73
My serpentine cooling coil is 3 years old now. In case I need to have it replaced, do you recommend that I get laminated or serpentine?
Since the original cooling coil for my car is serpentine, if I replace it with laminated, wouldn't it cause having other parts replaced as well?
September 5th, 2009 09:54 AM #74
September 6th, 2009 01:40 AM #75
Go for the laminated type na cooling coil. If your car is a typical japanese, look for a JDM surplus cooling coil then have the shop convert it for you. Difference between laminated and serpentine are night and day especially during summer/hot days.
September 6th, 2009 01:57 AM #76
What needs to be converted?
Why do you recommend a surplus cooling coil over a new one?
- Nov 2009
- 2
November 16th, 2009 02:07 AM #77
How much is the laminated type because yung pinalit sakin cost 5.5k serpentine type. I have a Mitsu Adventure, kung local daw ipapalit 3.5k , kaya I thought it was better.
Nagkaroon ng mga butas yung pinalitan na serpentine type in less than two years, got it from Berovic in Abad Santos near Tayuman. Bihira lang din gamitin yung sasakyan and yearly ang linis. Sana tumagal yung pinalit ng Ceejay's and hopefully di na magkaproblema.
I'm just wondering kung masyadong mataas yung price given to me for the serpentine? Ok lang din naman kung di na magkaproblema.
high idle RPM at engine start
