Quote Originally Posted by CoolSwitch View Post
Mga sir, ask ko lang ano possible cause bakit hindi lumalamig hangin ng AC ko.
Here's what happened:
Car: Nissan Maxima 89
Engine got recently replaced, then nagpa karga ako ng Freon, nag leak check naman yung nagkarga along the engine bay. So after ng karga, mukha naman ok, kasi umuwi ako ng malamig ang AC, and ramdam mo dun sa copper tubes yung lamig...
After a few days, punta kami hospital, doon ko naramdaman na di lumalamig ac, kapag naka_on naman gumagana condenser and you can also hear na nagbago menor.
I already tried all level settings, made sure na nasa cool yung isang switch, and AC button is pressed. kaso wala talaga.
Then tiningnan ko at sa engine bay yung device na may glass sa ibabaw, meron naman laman kasi may parang usok na gumagalaw, tried na pasingawin sa gas valve, meron naman,
pero funny thing is, nung hawakan ko yung copper tubes ng AC, walang lamig, kahit dun sa tube sa dalawang side nung part na may glass sa ibabaw
ano kaya problema?
just curious, did most of the members join the "pilipinibi" (philippine navy)? everybody seems to call the engine compartment which is less than a cubic meter engine bay. engine bay usually denotes a large part of a vessel housing a large engine capable of emplacing two main engines with accessory engines for cooling, engine for power production, engine for bilge pumps and etc. sorry, just curious. if this how it is called here, i understand
