Page 2 of 5 FirstFirst 12345 LastLast
Results 21 to 40 of 97
    Oct 2003
    #21
    or if you are going to park your car for long periods, push the fresh air in button (dunno whats that called) basta para yung air sa labas papasok? thats the problem of my honda city dati, when left re-circulating air, ang baho the next day, pero mawawala naman kaagad.
    also try blasting your fan speed way up when the air con is already off (when you are nearing your home or destination) para mawala yung lamig ng aircon.
    Aug 2003
    #22
    I've observed something similar on our 2007 Mazda3. But then Mazda3's are well known for their stinky aircon.
    Here's something I've done to avoid the stink on startup (it's not so bad on the Mazda3, just faintly annoying).
    About 3 minutes before you shut off the engine (say when you enter the parking), turn the A/C off but leave the blower running. It's even nicer if you switch the A/C from recirculate to allow outside air in. Run the blower on maximum, with the A/C off. This will evaporate any residual moisture.
    Also, you can try running the blower at maximum and heater at maximum for half an hour (the car will get very hot... do this at home). If there are any molds or something the waste heat from the engine will kill them.
    Dec 2007
    #23
    ok, so I did some little "investigation" earlier tonight and I turned on the A/C on the Camry and took it for a drive (since I have to go out to the store anywayz..)
    so I had the AC on for about 10 mins and I didnt smell a thing. but it was cold as hell though! plus it was already cold outside at around 40*F!! I was freezin my ass already! lolz! but still, no smell.
    aite, peace.
    #24
    Based on experience pag ang AC ay bumaho it means madumi na evaporator usually sa 2 year old car meron na..Just have it cleaned ok na...Pero 3 mo old car camry pa?? Hmm there must be something wrong..
    #25
    I think the service people of the Toyota dealer which was visited by the T.S. are total a**holes, no way would I pay P7,500 to fix the A/C of a new car with factory warranty to boot.
    Oct 2003
    #26
    Quote Originally Posted by suysuy View Post
    tip ko lang (not sure though hehe)
    wag mag spray ng pabango/perfume/cologne sa loob ng car. didikit sa filter yung amoy. kasama ang dirt. so babaho yan
    lalo na yung mga gel type na car freshener. where do you think the gel goes? sa filter. pag mag sublime yan diretso yan sa filter.
    I don't like perfumes as well napilitan ako sa bahooooo.
    Oct 2003
    #27
    Quote Originally Posted by orly_andico View Post
    I used to own a Mazda 3 2007 and the AC stinks but trust me the camry is 10x worst.
    Oct 2003
    #28
    I got a friend who refer me to bicutan toyota and they want to charge me 4,000.00 instead of 7,500.00 and they can do it in 1 days unlike 3 days of Toyota Shaw.
    I will try the Toyota-Shaw-Ortigas next week.
    Feb 2005
    #29
    before shelling out 4 grand...try out some of the recommended remedies listed above, you may just save yourself alot of money...
    Oct 2003
    #30
    I agree with you. The car now is running on heater for 30mins and I spray Lysol on the air intakes from the EXTERIOR which is suck all the way inside the evaporator.
    I hope it work. I'm sure the lysol went IN from outside since I can smell lyson inside the car vents.
    Feb 2005
    #31
    GOOD LUCK!!! hope all goes well...
    Oct 2003
    #32
    Quote Originally Posted by joeverzosa View Post
    Sorry to report none of the above work at all.
    The car was set to idle for 45 mins with heater at MAX with air circulation vent ON. The car was so hot inside when I got back to it.
    I also spray LYSOL towards the end on the air intake and hope it will get rid of the smell overnight. But the next morning when I started the car smell was reduce but only after 2hrs of using the car the park for 2hrs more then started it again the smell was back.
    I have now no choice but to have it service by Toyota.
    Feb 2005
    #33
    Well at least you tried...Let us know what they find...
    Oct 2003
    #34
    Finally found out that this thread had been moved to the workshop.
    The car is with Toyota Ortigas Shaw since Monday.
    They confirmed the bad smell ---- like basahan with water yucky!!!
    The reason why the car ended up in Ortigas-Shaw was I made a complain letter to TMP and they got back to me and advice me to bring the car to Ortigas Shaw.
    As per the Service Advisor they pull down and clean the whole system and I think some guys from TMP went there today to check the case of my car.
    I hope that they will fix the problem and give me back my car by tomorrow.
    I miss my car.
    Jun 2006
    #35
    Just ask them to replace the whole AC system. up to the last bolt.
    I would've or I'll demand unit replacement if I don't get full refund.
    Jun 2005
    #36
    im glad you didnt pay for this. i think its time for you to find another dealer to service your car .
    this is common with our infiniti suv and other nissans recently. do you turn off your car with the ac still on? or do you turn off the ac just right before you turn off the car? that may be the cause of it. try turning off the ac and leaving the fan on for a few minutes (or earlier than we normally do) before you turn off the car. also, if your car has a cabin filter, invest in a replacement filter with charcoal if possible. in my case i still smell it initially (if i forget to keep fan on longer) but much less than before.
    Oct 2003
    #37
    Finally I got the car today and it's smells clean now.
    They didn't charge me for the AC cleaning and I'm glad that they clean the whole system
    I hope this does not happen again.
    My usual practice is to turn OFF AC before turning OFF the engine.
    I will now try to practice FAN for 2mins before turning OFF the engine.
    We never had the problem with our SUV expedition or MB or CITY but it did happen with our Mazda 3 and Suzuki Vitara but the Camry has 10x more intensity in BAD ODOR compare to the two that had such issues.
    From now on Toyota Ortigas Shaw would be my favorite service center.
    #38
    Told you... Toyota Ortigas-Shaw does a good job in honoring warranty claims. :cool01:
    Aug 2007
    #39
    ano bang branch ng toyota dito ang mas maraming naibebenta na kotse? so in terms of service mas better pala sa toyota shaw..
    #40
    Quote Originally Posted by glenngj View Post
    It's Toyota Ortigas-Shaw (the one in C5) not Toyota Shaw (the one in Shaw).
2007 Camry AC STINKS!!!
