Page 9 of 10 FirstFirst ... 5678910 LastLast
Results 81 to 90 of 98
    Quote Originally Posted by bokswager View Post
    guys,
    kapag po gamit e distilled water sa pagrefill ng water reservoir, ilan po bang liters po ba na distilled water ang recommended para pag refill sa tank po.
    Thanks
    bottled drinking water pwede na. maka save ka pa 20pesos or so.
    dont waste water. pag umapaw sayang naman.
    problem lng sa tap water yun calcification.
    #82
    guys,
    Thanks
    most reservoirs have "full" marks on the plastic, or on the dipstick, visible even if one does not read the manual.
    of course, the owner's manual has it.
    Dec 2009
    #83
    ^fill to the brim lang yan
    Jan 2009
    #84
    For the windshield washer fluid, I've been using a brand called Rivers I bought in gallon jugs online.
    Before that, I used to have just plain filtered drinking water in the washer reservoir. It worked sorta fine but after trying out a proper washer fluid, I'm never going back.
    Anyway, these jugs still cost a pretty penny so I'm looking into using those tablet alternatives. You drop 1 tablet in a 4-liter container and let it dissolve for 15-20 mins, making sure that everything is fully dissolved before using it in the car.
    Anybody has anything good or bad to say about them? Any particular brand/seller I should look for or avoid?
    Jul 2013
    #85
    (post mo lang binasa ko... noticed na mahaba na itong thread)
    my detailer hates soap and any product sa washer fluid... distilled water lang daw gamitin ko.
    problem ko now is that Toyota also uses a washer fluid kaya di ko madala dala sa kanya Zenix namin
    Jan 2009
    #86
    Washer fluid is not overrated, as I found out. I did the distilled water thing several years ago but water alone is not good at dissolving non-water-soluble stuff like most road grime, bugs, oily/greasy smudges, etc. Like I said, it sorta works but not as well as a properly formulated washer fluid.
    And I'm not talking about homemade washer fluid from dish soap or shampoo either. They're unusable when it's not raining (to rinse off the soap). Otherwise, it causes streaking.
    #87
    Need pa ba ng total draining yung reservoir if lalagyan o pupunuin ng washer fluid mula distilled water? Tia.
    Jan 2009
    #88
    No need. Gamitin mo lang hanggang maubos at mapalitan yung distilled water. Ganyan lang ginawa ko.
    Jun 2011
    #89
    Gamit ko distilled water na may mga 1 tspn ng (Rivers) car shampoo.
    #90
    This is what I’m using.
Windshield Washer Fluids Talk
