Results 1 to 10 of 17
July 18th, 2012 09:48 PM #1
Nagpalit po ako Unipoint Soft Wipers/Banana Type. Pati likod sinabay ko na.
*480each yung harap 20"
*380 likod 15" (soft din)
Hirap maghanap. Nalibot ko na banawe isang shop lang meron kaso yung ordinary di soft/banana.
Mag bosch aero soft banana type sana ko kaso 1.5k pair pa lang.
Googled kung san ang dealers, sa masangkay cor recto daw meron.
Dito ko nakakuha.
Rotary name ng store, Dealer talaga sila Unipoint.
1133 G Masangkay St. Sta Cruz
251-7787, 251-1063
0917-8900900, 0922-8999866
www.rotaryauto.com.ph
Eto po description from a seller sa sulit kaso wala sya ready stocks by order pa daw kay dumerecho na ko sa dealer.
Unipoint wiper blades (Aeroblades) are flawlessly quiet because its rubber is graphite coated. Graphite coated meaning, it does not produce a squeaking sound when wiping the windshield and kung papansinin niyo pag hinawakan niyo yun blade madumi siya yun ang Graphite Coated Rubber yun ibang brand wala niyan Secondly, the rubber doesn't go brittle when subjected to heat and the cold temperature (rain temperature). Thirdly, Unipoint is the manufacturer (maker) of Bosch wiper blades (aeroblades). Which means, Bosch and Unipoint blades are the same and performs exactly the same except of course for the packaging and the price.
http://www.unipoint.com.tw/aboutus.htm
- Oct 2010
- 109
July 21st, 2012 11:16 AM #2thank you sir for sharing. planning to change my maingay na windshield wiper.
August 25th, 2012 12:55 PM #4
- May 2012
- 372
August 27th, 2012 02:51 AM #5eto din gamit ko. served me good for 2 years at di pa dapa ang blades. yun nga lang need to change it na coz may mga naiiwan ng water pag wipe nya so sa gabi an hirap ng makakita pag nag wiper lalo na may kasalubong at masisilaw ka.
smooth ang hagod, oem type pala ang gamit ko.
- Aug 2012
- 24
August 27th, 2012 05:33 AM #6gamit ko din to mga 6months pa lang ata tong sa akin maganda malinis ang wiping capabilty, sa maruzen wiper dalawang buwan lang gamit streak na...
15" price at 240.00 set
September 2nd, 2012 07:43 PM #9
September 6th, 2012 03:24 PM #10
As long as it is valid, bring a printed copy. Then, they will ask you to use one of the PCs there...
