Results 1 to 10 of 12
September 14th, 2015 10:50 PM #1
mga katsikot need help, ano kaya pwede pangtanggal ng malabong parang film sa windshield? nahihirapan kasi akong makakita lalo na pag gabi at maulan.
nagtry na ko ng baking soda, baking soda w/ vinegar & lemon. walang epekto.
thanks and more power!
September 14th, 2015 10:57 PM #2
Inside or outside?
Inside is the evaporated oil from the dash. Either from the plastic or from the greasy dash protectant you are using. There are some light degreasers you can use on the inside. Then use a glass cleaner.
Outside: prolly calcium residue. Using a glash polish can help remove this calcium layer.
Use drinking water in your washerfluid reservoir. Using your washer fluid lessens calcificaton.
- Nov 2014
- 93
September 15th, 2015 01:27 AM #3
September 15th, 2015 12:00 PM #4
windshield detailing lang katapat nyan bro. leave it to the experts na lang, sakit sa kili kili nyan lalo na sa loob.
September 15th, 2015 01:07 PM #5
actually mga sirs pinadetail ko na yan nung linggo tapos kagabi umulan, pag wipe ko ng windshield biglang naging ganyan.. ginawa lang ng nagdetail parang acid rain removal lang ginawa walang buffing.
- Oct 2009
- 2,271
September 15th, 2015 02:11 PM #6naka on ba AC mo or hindi,
ang ginagawa ko dyan best solution.bili ako rubbing compound halagang 50 pesos..20 pesos na kerosin.saka buffing machine tapos yan sa loob ng 20 mins..
September 15th, 2015 04:08 PM #7
based on the picture, its moisture from the inside.
have you tried adjusting your aircon and vents when it rains?
September 17th, 2015 08:15 AM #8
ac on po mga sirs iba moisture ng hindi on ang ac mas malabo pa dyan..
*ned magakano ganyan?
September 17th, 2015 08:37 AM #9
ganyan din nangyayari sakin.
workaround ko is lakasan yung AC, tapos wiper nalang. madalas ito pag umuulan tapos mas malamig ang temp sa labas compared sa loob.
sinubukan ko rubbing compound plus mano mano wipe ng wax applicator = hairline scratches sa windshield
September 17th, 2015 10:07 AM #10
Seen videos of windshield detailing using steel wool grade 0000. Sa mga forum sabi ok naman and hindi nakakagasgas. Problem is where to get that grade. Nagikot na ako sa ace, true value, Japan home, wilcon and mc home and pinakamanipis nila ay 0 grade lang. Hindi daw advisable sabi sa mga napanood ko. Interested ako bumili so I might go for an online purchase. Yung isang sasakyan kasi meron din ganyan sa windshield and lumalabas siya kapag bumibiyahe sa cold places like tagaytay in the wee hours of the morning. Medyo delikado
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
