Results 1 to 12 of 12
    Aug 2013
    mga katsikot need help, ano kaya pwede pangtanggal ng malabong parang film sa windshield? nahihirapan kasi akong makakita lalo na pag gabi at maulan.
    nagtry na ko ng baking soda, baking soda w/ vinegar & lemon. walang epekto.
    thanks and more power!
    Inside or outside?
    Inside is the evaporated oil from the dash. Either from the plastic or from the greasy dash protectant you are using. There are some light degreasers you can use on the inside. Then use a glass cleaner.
    Outside: prolly calcium residue. Using a glash polish can help remove this calcium layer.
    Use drinking water in your washerfluid reservoir. Using your washer fluid lessens calcificaton.
    Nov 2014
    Quote Originally Posted by Pawo1 View Post
    ganyan din saken dati.. bumili lang ako ng ganito sa blade at inapply sa windshield/windows.. ok na. try mo :-)
    once a month lang daw gamitin. once ko lang inapply tapos naka-ilang car wash nako pero ok pa din..
    windshield detailing lang katapat nyan bro. leave it to the experts na lang, sakit sa kili kili nyan lalo na sa loob.
    Aug 2013
    actually mga sirs pinadetail ko na yan nung linggo tapos kagabi umulan, pag wipe ko ng windshield biglang naging ganyan.. ginawa lang ng nagdetail parang acid rain removal lang ginawa walang buffing.
    Oct 2009
    naka on ba AC mo or hindi,
    ang ginagawa ko dyan best solution.bili ako rubbing compound halagang 50 pesos..20 pesos na kerosin.saka buffing machine tapos yan sa loob ng 20 mins..
    based on the picture, its moisture from the inside.
    have you tried adjusting your aircon and vents when it rains?
    Aug 2013
    ac on po mga sirs iba moisture ng hindi on ang ac mas malabo pa dyan..
    *ned magakano ganyan?
    ganyan din nangyayari sakin.
    workaround ko is lakasan yung AC, tapos wiper nalang. madalas ito pag umuulan tapos mas malamig ang temp sa labas compared sa loob.
    sinubukan ko rubbing compound plus mano mano wipe ng wax applicator = hairline scratches sa windshield
    Dec 2004
    Seen videos of windshield detailing using steel wool grade 0000. Sa mga forum sabi ok naman and hindi nakakagasgas. Problem is where to get that grade. Nagikot na ako sa ace, true value, Japan home, wilcon and mc home and pinakamanipis nila ay 0 grade lang. Hindi daw advisable sabi sa mga napanood ko. Interested ako bumili so I might go for an online purchase. Yung isang sasakyan kasi meron din ganyan sa windshield and lumalabas siya kapag bumibiyahe sa cold places like tagaytay in the wee hours of the morning. Medyo delikado
    Aug 2013
    update ko lang mga katsikot.
    kahapon binalik ko sa carwash para ayusin, binuff naman nila.
    tignan ko ulet bukas kung magkakaroon nanaman nyan.
    Aug 2015
    sir baka po ung ginamit nyong pang wipe hindi maganda. nangyare saken yan ung pipitsuging basahan dumidikit ung lint nya sa loob. hirap na hirap ako tanggalin ang ending pinapalitan ko ng tint since gusto ko na din gawing mas dark ng onte hehe.
Need help hazy windshield
