Results 961 to 970 of 1031
- Feb 2013
- 927
October 19th, 2017 12:04 AM #961*Stockengine
I couldn't help but read the quoted post of jut abovrme where he mentioned that only the VK series is metallic in VKool's lineul but you said a few days ago that the X and the K series are also metallic.
Which is which?
October 19th, 2017 12:10 AM #962
X series has high TSER because of the multi-layered advanced metal matrix composite aka MMC
the VK series and X series are Metallic.
ABOUT METAL MATRIX COMPOSRE (MMC)
The V-KOOL X05 series is a multi-layered MMC stack, which consists of a titanium composite material coupled with a metallic alloy, both sputtered onto top grade PET substrate. The MMC material derived from this titanium composite-metallic alloy combination results in a fusion of high performance materials that improve properties in automotive application in terms of fatigue or wear resistance, thermal conductivity, engine efficiency and others.
MMC is nearly always more premium and value-for-money than the more conventional materials they are replacing. In many instances, MMC using such titanium composite material have been shown to provide a performance advantage over a monolithic metal. Its applications are also found in space systems and high-end or "boutique" sports equipment.
- Nov 2007
- 85
October 23rd, 2017 07:27 PM #963*stockengine sir, do you have a recommended tint for sunroof? which brand and shade. thanks
October 23rd, 2017 08:06 PM #964
huper optik "ceramic" range is premium non metallized tints.
I prefer sunbloc ultra for my next purchase though.
go for light vlt(40-80%) for the sunroof if you want to see the beautiful blue skies or evening stars or even the rain. i keep my sunroof open in
the evening. if its dark you cant see much.
- Jul 2013
- 11
October 24th, 2017 09:00 PM #965
October 24th, 2017 09:05 PM #966
vkool vip black(05) but its not yet available locally...
vk oem5 is very good also
- Dec 2009
- 40
November 29th, 2017 01:23 AM #967which tint is the best in heat rejection, night time visibility and privacy? i've found a relatively new comer (ithink) solariod tint. please advice on this. or can you recommend tints that have all the best qualities for the three points above? TIA!
- Oct 2017
- 20
November 29th, 2017 10:42 PM #969*stockengine sir, can you recomend which is better? vkool or huper optik?
November 29th, 2017 11:28 PM #970
if you rely on your gps and need to get good phone signal get the huper..
i have the vkool vk70 and i drive 2-10hrs/day nakakainis konte that the signal isnt as strong.
Interesting thread—really important to consider the broader impact of the National ID Law beyond...
National ID Law
