Results 61 to 70 of 79
August 12th, 2017 05:57 AM #61
Stainz out didnt work so well with mine, but the elevo watermark remover did
And there's a watermark remover brand that I keep seeing online called express glass restorer and it looks promising. Has anyone tried this one?
- Dec 2012
- 15
August 26th, 2017 10:12 AM #62Sirs buhayin ko lang to thread...
Anyone tried glass science products at san makakabili?
Thanks Sirs
August 26th, 2017 10:30 AM #63
^ sa true value atc meron niyan so i suppose sa other branches nila meron din
when you look into the abyss, the abyss looks into you
- Dec 2012
- 15
- Aug 2017
- 2
August 28th, 2017 02:59 PM #65Window cleaning is a very difficult task since it is made up of compound curves. Also, most of the hard water impressions on the window are only visible in the direct sunlight. I think it requires very strong chemical cleaner or microfibre cleaning cloth to clean the window perfectly. I have used ammonia once for cleaning the window but it left streaks on the glass. After that, I used to wipe the glass with a window cleaner and wipe it again with a micro-fiber cloth. Also, I used to clean the window with back and forth and then up and motion. I don't prefer circular motion. The window cleaning service providers clean in such a way. They also recommend not to clean the glass in the direct sunlight. It might leave spotty residue in the glass.
- Oct 2016
- 41
August 29th, 2017 01:13 AM #66Well I supoose it won't work so well in untreated watermarks, those left for a long time. Sa Monty namin ganun. I could say it works somehow but had to repeat it a few more or even several more until it's totally free of watermarks.
Sent from my SM-G930F using Tsikot Forums mobile app
- Oct 2016
- 41
August 29th, 2017 01:16 AM #67Update us sa result kapag na try mo
- Aug 2017
- 232
September 11th, 2017 10:55 AM #68Hi, what's a good and safe product to use on your windshield on an every day basis? Or every other day.
Sent from my EVA-L19 using Tsikot Forums mobile app
September 11th, 2017 01:23 PM #69
- Aug 2018
- 1
August 20th, 2018 07:34 PM #70Having problems with acid rain spots on your car's windshield?bathroom enclosures or chrome materials?this might be your solution!!
https://bit.ly/2ORyUJs
I have a digital gauge that measures, among other things, engine coolant temp. 90% of the time,...
