Results 11 to 17 of 17
November 9th, 2012 11:06 AM #11
November 9th, 2012 11:30 AM #12
If heat rejection is also important, go for the more expensive tint brands with at least 30% VLT for your WS.
For comparison, I have Huper Optik Ceramic Series (CS) 30 on my WS. Helps with the heat, glare from incoming vehicles and visibility at night is relatively awesome. My windows are VKool OEM 05. Sobrang dilim. My rear glass is still sa stock 3M Black Chrome 35, relatively useless. I plan to change them all to HO din after maka-ipon, quite an investment pa (around 15K~ pa).
- May 2011
- 191
November 9th, 2012 03:36 PM #13
November 9th, 2012 06:30 PM #14
Driving school lessons, day 2.
If you have oncoming high beam headlights, you turn your gaze towards the gutter, slightly to the lower right. Problem solved.
If you tint your windshield below 30% VLT to "cure" this problem, you should not be driving.
Driving realizations, a few years later.
Once you are close enough to see oncoming car headlights split from one light to two, you should dip your headlight beam to the low setting.Last edited by Type 100; November 9th, 2012 at 06:37 PM.
- May 2011
- 191
November 10th, 2012 01:26 AM #15Like I already said, will go for the lightest black shade of tint for the front windshield, which is around 40% VLT if I remember reading correctly. At least the black shades have better glare reduction than the magic/chrome variants, say some consumers. Turning head to the gutter? Textbook teaching is different to reality especially with so many variables to take into account, having said that I've tried it before and it's fine for the first few punters but for the succeeding hundreds and thousands no thanks. Alternative sought.
- Aug 2012
- 2,767
November 10th, 2012 08:01 AM #16^the opposite is true, Magic/Chrome tint provides better glare reduction because they have higher VLR (Visible Light Reflectance) properties.
Visible Light Reflectance (VLR)
The amount of visible light that is reflected by the glazing system, expressed as a percent. A higher VLR rating offers better glare control. Films with higher ratings tend to be more reflective and/or darker.
Example VLR ratings for 3M "Magic" and "Black" shades..
3M BC-35 -- Light Magic (13% VLR)
3M BC-20 -- Dark Magic (20% VLR)
3M BC-10 -- Super Dark Magic Neutral (22% VLR)
3M FX-35 -- Light Black (5% VLR)
3M FX-20 -- Medium Black (5% VLR)
3M FX-5 -- Super Black (5% VLR)
- May 2011
- 191
Ah ok. So Wala pa Lang locally released na delicą dito. Pinapakyaw kasi Ng mga outdoor lovers...
Mitsubishi Philippines
