Results 1 to 10 of 14
- Apr 2011
- 10
February 24th, 2012 10:34 AM #1What do you think?????? I had my Volvo S40 1998 model engine wash, right after I noticed the car hardly move and obvious drag in the engine. It starts and run but the drag when you drive is terrible and makes engine hamming hard. There was a sign at the dashboard, the lambda sign, which according to manual was 'failure in the engine electronic system'. I want to know which part in the engine needs replacement? Thank you for you help. You may reply as well at ricsan07*yahoo.com
February 24th, 2012 10:53 AM #2
water must have went into a sensor or terminal
baka airflow sensor
dunno
February 24th, 2012 11:04 AM #3
kailangan na ng OBD to read the ECU kung ano ba problem.
kaya mahirap mag engine wash ng sasakyan with sensors.
- Apr 2011
- 10
February 24th, 2012 11:25 AM #4
February 24th, 2012 11:32 AM #5
there are a number of sensors sa engine. every sensor has a terminal connected to it. all of them goes to the ECU
sa pag washing may nabasa na di dapat mabasa
just hope nothing happened to the ECULast edited by uls; February 24th, 2012 at 11:34 AM.
- Apr 2011
- 10
February 24th, 2012 11:33 AM #6Thank sa reply Crazy_boy...tama ka, di alam nung nagwash din... I have my personal OBD, di ko lang alam gamitin, pero my indicator nasa dashboard as stated, I'll try suggestion ni Uls sa sensor. Volvo S40 lancer ang parts nyan, kaya hanap kolang which part there was the sensor or terminal as suggested by Ils.
- Apr 2011
- 10
February 24th, 2012 11:38 AM #7Thank you again Uls..appreciate it...Also what do you call that cables going to the sparkplugs in the engine?
February 24th, 2012 11:39 AM #8
- Apr 2011
- 10
February 24th, 2012 11:48 AM #9Thank you Ghost for the reply... December pa it happened but until now hamming is still there and no power to mave normal. How do you reset the ECU?
February 24th, 2012 11:52 AM #10
Very informative discussion guys. Thanks a lot!
Liquid tire sealant
