Results 1 to 10 of 14
    Apr 2011
    Thank you again Uls..appreciate it...Also what do you call that cables going to the sparkplugs in the engine?
    Quote Originally Posted by ricsan07 View Post
    i call them spark plug wires hehe
    other people call them hi-tension
    Apr 2011
    Thank you Uls...One time, its I think a little technical, a mechanic saw while testing, that tube being inserted into the sparkplugs has its electric exiting out of tube, he said there was a leak which supposed to be all its electric power just goes down the plugs. He wrapped them around with electric tape. I really do not know if it was correct or really if I have to replace the hi-tension cable that you call it?
    The insulation on the sparkplug wire (high tension wires) has a defect which lets stray electric current to discharge. Generally you will have to replace the wire.
Vollvo S40 "Failure in Engine Electronic System"
