Page 1 of 2 12 LastLast
Results 1 to 10 of 18
    Feb 2019
    Good day mga Sir. papatulong sana ako sa problem ko. I have a starex 99 matic. regarding po ito sa brake. kung mga b'brake ako. kumagakagat nmn at first. then next brake ko. tumitigas na ung brake pedal niya at mahirap na i'brake tsaka umiilaw ung brake warning lights. at kong hahayaan ko muna mga ilang minutes. nag o'ok nmn po siya. pero everytime magbrake ako. nag'o-occur po ulit ung problema niya hard pedal braking. anu po kaya probs nun?.
    salamat po. sana my mka tulong sakin.
    Quote Originally Posted by Freedom25 View Post
    brake fluid level checked? when was the brake fluid changed?
    Feb 2019
    never pa po ako ngpalit ng brake fluid sir. pero dinadagdagan ko lng kung wla sa max lvl. need po ba ipa flush out ung brake fluid and change fluid?
    Thanks po.
    Jan 2009
    The problem is around the brake booster.
    Check for vacuum leaks.
    Whenever there's not enough vacuum in the brake booster, the brake pedal gets harder and the brake warning lamp lights up.
    Thanks po.
    how often do you open and top up? opening the reservoir will make the fluid suck in water and will spoil the fluid. I suspect a leak also..
    Feb 2019
    bihira ko lng po binubuksan ung reservoir. unless kung merong mga long rides nag'i-inspect po ako ng mga reservoir such as brake fluid at coolant. pero wla namang leaks occuring at all the brakes at the tires even in the lines Sir.
    Tanong ko lang Sir. Saan po banda nka tap ung Hydrovac ng hoses at lines sa intake manifold. I have a d4bh tci engine.
    Thanks a lot Sir for your help.
    Feb 2019
    Sir Are you familiar with starex engine? (d4bh tci engine) di ko kasi alam if merong check valve sa lines ng hydrovac. since doon mismo sa booster eh wla pong check valve doon. i think sa tapping point ng intake manifold. but i cant identify kung saan banda nka tap ung linya ng hydrovac kasi umikot sa likod nung makina ung tubo ang hose kung kayat medyu mahirap po mkita kung saan patungo.
    Thanks sa tulong nyu po Sir
    iisa lng vac lines papasok ng brakebooster(big round thing attached to the brakemaster) you can trace from there.
    Jan 2009
    This is what the brake booster on the Starex would look like (with the brake master removed).
    In the picture, the vacuum hose is on the upper-right, and the brake booster vacuum sensor at the bottom left.
    Feb 2019
    Sir sinubokan ko na po i'trace kung saan banda sa intake nka tap ung vaccuum hose ng hydrovac. tlagang mhirap. kasi umikot sa likod ng makina ung tubing at hindi ko rin masyudo msilip kasi limited tlga ung space under the hood ng starex. padating nmn sa intake dami nang tubes ang nkalabas at tinakpan pa ng EGR, Turbo charge at mga manifold ung mga tubing. kaya tlgang pahirapan ung pag'trace Sir.
help po mga Sir about brake issues
