Results 1 to 18 of 18
    I just got a second hand Buddyclub shiftlight. It doesn't have the cigarette lighter plug socket anymore.
    Can anyone please suggest a shop where I can have this installed?
    Thanks in advance to your replies
    8)
    you might want to try sa Fusion R sa may E. Rodriguez. The shop is near the Petron Station, corner tomas morato. I'm sure they know how to do it.
    You can have it installed at Group5 along shaw if their mechanic is still working for them. They did a few installations of such before.
    he he... hey dexlab! di ko pa nakabit eh... next week siguro pag balik ko manila.
    ghosthunter,
    thanks man. try ko dun or sa Fusion R. pero diba iba na may ari ng Group 5? iba na pangalan nung shop nila eh.
    Supierreman,
    The Buddy Club Shift lite doesn't have the lighter plug at all, it attaches directly to the tach output of the distributor or tach input signal behind the gauge cluster.
    The type that goes into the lighter plug uses a different signal pickup system.
    Auto_Xer,
    thanks for the info! ...i'll have it installed probably next week. If there are problems consulta ako sa yo
    whats so special about this "Buddy club shift light"?
    you just attach to the cigarette lighter just like a cellphone charger?
    MAXBUWAYA,
    Yung nakuha ko kay Dexlab sabi ni Auto_xer yan yung model na wala palang Lighter plug. Yung pivot shift light yung pwede sa lighter plug.
    Auto_xer told me na sa Fusion R ko pakabit. Probably this sat siguro
    wala lang... minsan kase I like to shift my car at the limit para ma maintain ko lang VTEc kahit sa single cam lang ...Buti pa SiR mo... lakas! If you want din you can install a shift light in your Weapon car diba. masaya yun!
    Rev it up to redline... shiftlite on... shift up... rev it all again... shiftlite...shift up! :P
    Quote Originally Posted by MAXBUWAYA
    Its just another brand of "shift lights". Its rather simple to install and works pretty well. Its also one of the smaller types of shift lights. Most others look like big metal tubes kasi.
    Having a shift light is an advantage when racing because you can do consistent shifts at the proper RPM level you have set.
    supps
    nabili mo na pala yung shiftlight kay dex. :D
    otokoto,
    yep! :mrgreen:
    Quote Originally Posted by otokoto
    supps
    suppps
    how much mo nga pala nabili yan? may nag-aalok kasi sa akin eh
    Finally sa tagal ng na sa akin shift light na toh kahapon ko lang napakabit
    Busy kase masyado buti na lang kahapon half day lang so I had it installed at Fusion R.
    Dali lang pala yung install... they just spliced some wires to the ECU and tapped the BClub Shiftlight. Ok na sya parang ilong ni rudolph he he :mrgreen:
    otokoto,
    yep same price pa rin as posted noon.
    ghosthunter,
    i'm not sure kung ikaw yun pero diba you had this type of shiftlight in your car before? Yung sa yo ba when the light activates nag bli blink ba sya? di ba sya straight continuous light on... yung sa akin kase pag umabot na sa shift point blinking yung read light eh.
    Quote Originally Posted by Supierreman
    ghosthunter,
    It blinks the big red light when you have reached the trigger level of the shift light. BTW, I currently have the shiftlight in my car pa din.
    ghosthunter,
    thanks kala ko may problem yung shift light ko he he...
    BTW... wala ba kinabit na power supply dun sa shiftlight mo or any relays? yung sa akin kase nakatap lang sa wires sa may ECU.
    bad trip I just saw this post in Autoindustriya a shiftlight for sale for only P2,000 :o ... sayang... got mine forP3,500
    ghosthunter,
    nope, no other wires. Just like your setup.
    depends... it might be a different type that you might not like.
    thanks ghost
    Feb 2011
    Anybody know where to get this shift light new or used?
Buddyclub Shiftlite installation
