Page 9 of 9 FirstFirst ... 56789
Results 161 to 179 of 179
    Quote Originally Posted by newtocar View Post
    "When the car is in D and you start the engine the hydraulic pump in the automatic transmission is not providing fluid pressure until the engine starts.
    This fluid pressure is used to engage clutches in the transmission to engage first gear or reverse.
    An automatic transmission does not have gears like a manual transmission which are physically meshed into one another or engaged.
    The gears in an automatic transmission are always engaged or locked in but they are coupled to the drive shaft by multiple different clutches that are selected either by you or automatically. This is called the planetary gear and clutch system and it is very difficult to conceptualize.
    In an automatic transmissions N is actually the same as D in that none of the clutches are engaged except in D there is a mechanical connection to an internal transmission brake. This brake has nothing to do with your wheel brakes and it come on mechanically so the engine does not need to be running for it to work.
    In D when you�re at a stop the main forward clutches are engaged and the torque converter is providing pressure to rotate the forward gear but it does not rub or wear when it is doing this. Because of this resistance to free rotation in the transmission the engine begins to slow. In a modern car there is an idle control valve which the computer opens to increase air entering the engine so the engine does not stall. So there is actually more air entering and the computer senses this and adds a bit more fuel as well. So in D at the light your car will use a little more fuel than if it was in N.
    Also the wheel brakes are not rubbing but are stopped and they will not wear at all while holding the forward creep of the car when in D.
    The forward creep is caused by the transmissions torque converter. There is nothing slipping or wearing or heating up to any significant extent in there. It�s all done hydraulically and nothing is wearing to worry about. BUT!!!! When you are in N and the engine is turning and the wheels are stopped then for this to occur the main forward clutch is disengaged and it is SLIGHTLY SLIPPING. So the clutch plates are wearing.
    So you are actually wearing out the main wear component in an automatic transmission being the clutch plates if you shift from D to N at a stop. The only advantage is your saving a very small amount on fuel.
    Personally I DO NOT and I have been told by an automatic transmission engineer that you should never shift the transmission from D to N at the lights. The reason being you are wearing your clutch plates in your transmissions. It also gets hotter because of the friction and the dirtier transmission oil then contributes to other component failures.
    Also it�s dangerous to be sitting there in N. You may need to drive away all of a sudden to avoid an accident but in N there is less chance of do this. You also may select the wrong setting like R when you wanted D.
    If N should be selected at the lights then engineers would have incorporated this into the design. But they did not. On some fuel saving cars the engine now shuts off at the lights so obviously N is selected automatically by the computer during the shutdown period so the car can be restarted. But the engine is not turning so the clutch plates are not slipping and wearing in this type of fuel efficient car.
    Also if your car vibrates in D at the lights then you need to get it serviced. It should not vibrate excessively at the lights if everything is working fine."
    .....Taken from the net....
    Source please, I highly doubt it. When in N there are actually no rubbing of internal parts. Parang may mali sa explanation. Why would car manuals specify to put the gear in N when in a prolonged stop?
    http://www.topgear.com.ph/features/c...uck-in-traffic
    Apr 2015
    Hmm I guess they seem to think more gas consumption and more load to the brakes is okay. But I'll stick to what I think is best.
    Apr 2015
    #164
    ^ it is always the operator's preference what to follow. If you look at the comments of TGP feature column (shifting to neutral ....) some disagree to TGP's reply.
    Anyway, we own our vehicle, so we do what we believe right for it.
    Jan 2009
    #165
    You'll just have to balance it. While stopping for several seconds, it should be ok to leave it in D. But if the stop is going to be longer than a few minutes (or if you've been stationary for more than a while already), putting it in N would allow you to relax your foot. With the brake lights off as well, the driver behind you would be thankful.
    Shifting it between N and D too frequently will theoretically add wear to the shifter linkages, as well as some added wear to the pertinent clutch (with the engaging and dis-engaging). Clutches don't wear out when they're either fully engaged or fully dis-engaged. It's when they first make contact in which a little bit of slip happens, is when clutches wear a bit of their friction material. So the idea is to keep the shifts to a practical minimum.
    Dec 2007
    #166
    What about CVTs? Does it make sense to switch to neutral on traffic light stops?
    #167
    Quote Originally Posted by Jeffrey Perez View Post
    So kung normal stop and go, ok lang na wag na ilagay sa N at D nalang? Sa US kasi, they really don't bother putting it to N unless 5 to 10 minutes ka naka idle.
    putting it to N while idling, reduces the wear and tear that would occur should you put it in D.
    the wear and tear will be in the engine, the trans box, and the brakes.
    there might also be just a wee bit increase in fuel consumption..
    the argument of N versus D for CVTs, are just like traditional ATs. see above.
    no big deal, really. it's up to you.
    Jun 2015
    #168
    After reading that argument that it's ok to keep it at D, I gave it a try this morning. My vehicle would slowly creep forward with the handbrake engaged. Handbrake issues or not, N na lang talaga ako for safety.
    sent via Tapatalk
    Feb 2009
    #169
    sent via Tapatalk
    Free country, your car. But leaving it in D range prevents shift shock from N to D.
    Dec 2007
    #170
    I'm not sure if what I'm experiencing is shift shock but the transmission jerking is more pronounced from D to N than N to D. In fact, N to D is quite smooth and jerking is almost non-existent. Without stepping on the brakes or gas pedals, I can shift from N to D and the car will just start to move slowly on its own. 2015 Altis CVT.
    Jan 2009
    #171
    It may seem weird but a bit of shift-shock is actually good for the A/T's longevity. If an A/T transitions to a gear with little or no shift-shock, it may mean that the clutches spends more time rubbing before they actually bite.
    Hondas in general have a very 'grabby' A/T. That's why they require a specific ATF... not to mention that their A/T is not of traditional design as it does not use a single planetary gear set. In fact, it shares a lot of its design from a traditional M/T.
    But more to the point, a lot of people think that the smoother the shift, the better. That's not always the case. Some would swear by the non-Honda ATF that they use, stating that the shifts have gone smoother than what they were experiencing with OEM fluids. Little do they know that the little stunt they did may have increased the wear on their clutch packs.
    #172
    Neutral..
    MT or AT...
    pag traffic at full stop. pareho ang procedure, ilagay agad sa N. para iwas strain sa transmission at iwas disgrasya
    (accidental release ng clutch kung anong gear ang engaged, or SUA kuno dahil naka D)
    Inclined and Steep parking... bago ilagay sa P, galing sa D or R, ilagay muna sa N.. angat ang handbrake, then release the brake pedal...saka ilagay sa P...
    para hindi magkaroon ng hard-shift from P going to R or D...
    Sep 2016
    #173
    *jyg1995 thanks.
    Another noob question, yung mga kakilala ko lagi ako dine discourage to buy an AT car kasi daw di mo "mahihila" pag nasiraan ka. I don't if they're saying literally or may ibang meaning.
    But let's say di mo nga mahihila, base on your answer, it seemed like "mahihila/matutulak" mo naman sya paga naka Neutral? just like a manual transmission right?
    Just want to re-open the thread. Newbie din kasi ako when it comes to A/T cars. Siguro, what they are trying to say, pag na-lowbat ka at nakalagay sa "P" ang transmission mo, you won't be able to put it down. Tama ba ako? Correct me if im wrong. Hahaha!
    Sa tucson kasi namin, nagagalaw ko naman yung kambya even if the engine is off. While few weeks ago I tested an all-new montero na naka-display sa mall, hindi ko magalaw yung kambya kahit pindutin ko na yung button sa harap ng stick. Sabi ng sales executive nila, safety feature daw yon. Pag naka-off, hindi mo daw maibababa yung kambya. It's an automatic guys ha baka isipin niyo manual since stick ang term ko. Di ko na kasi maisip. LOL.
    So sa isip ko lang, "Ah ganon pala yon pag matic."
    Quote Originally Posted by Offroad_Goals View Post
    pano ang tow or ilalagay sa trailer ang sasakyan pag ayaw mag start ng makina?
    #175
    Baka makakambyo kung apakan mo muna brake?
    Aug 2004
    #176
    Ang gen2 Vios may button sa center console tabi ng shifter para pwede i-unlock ang tranny kahit patay ang makina. Great for pushing the car around without having to turn the engine on.
    Some cars hide their buttons under a flap that can be removed using a flathead screwdriver.
    Other cars require disassembling half the center console
    Sep 2016
    #177
    That one I wasn't able to try kasi nasa mall kaya nahiya nalang ako magtapak tapak. Pero nung tinanong ko sa sales nila ang sabi, safety feature daw ng montero na bago, as long as naka-off hindi daw maibababa yung gear kaya sabi ko nalang ah okay
    Hindi ko sigurado. All-new montero owners here? Meron naman yan siguro dito. Hehe.
    #178
    johnM said it. some cars have a way to put the car to N, so that the car can be pushed around or towed.
    my 2003 altis has one such.
    read the manual, po. it's there siguro.
    and i agree. some display associates do not know their product enough. i actually prefer to talk to an owner than to a SA.
    #179
    Yung 1st gen Innova meron din shift lock button, very helpful lalo na pag nala double park ako dito sa parking sa office
    golden rule kasi yun, you can double park as long as maitutulak oto mo
what's the use of "N" in a AT?
