Results 161 to 170 of 179
January 16th, 2016 06:42 PM #161
Source please, I highly doubt it. When in N there are actually no rubbing of internal parts. Parang may mali sa explanation. Why would car manuals specify to put the gear in N when in a prolonged stop?
http://www.topgear.com.ph/features/c...uck-in-trafficLast edited by Ry_Tower; January 16th, 2016 at 06:52 PM.
- Apr 2015
- 104
January 16th, 2016 07:26 PM #162
January 16th, 2016 07:37 PM #163
- Apr 2015
- 104
January 16th, 2016 08:24 PM #164^ it is always the operator's preference what to follow. If you look at the comments of TGP feature column (shifting to neutral ....) some disagree to TGP's reply.
Anyway, we own our vehicle, so we do what we believe right for it.
January 16th, 2016 08:33 PM #165
You'll just have to balance it. While stopping for several seconds, it should be ok to leave it in D. But if the stop is going to be longer than a few minutes (or if you've been stationary for more than a while already), putting it in N would allow you to relax your foot. With the brake lights off as well, the driver behind you would be thankful.
Shifting it between N and D too frequently will theoretically add wear to the shifter linkages, as well as some added wear to the pertinent clutch (with the engaging and dis-engaging). Clutches don't wear out when they're either fully engaged or fully dis-engaged. It's when they first make contact in which a little bit of slip happens, is when clutches wear a bit of their friction material. So the idea is to keep the shifts to a practical minimum.
January 16th, 2016 09:30 PM #166
What about CVTs? Does it make sense to switch to neutral on traffic light stops?
- 54,293
January 16th, 2016 09:47 PM #167putting it to N while idling, reduces the wear and tear that would occur should you put it in D.
the wear and tear will be in the engine, the trans box, and the brakes.
there might also be just a wee bit increase in fuel consumption..
the argument of N versus D for CVTs, are just like traditional ATs. see above.
no big deal, really. it's up to you.Last edited by dr. d; January 16th, 2016 at 09:49 PM.
- Jun 2015
- 2,751
January 17th, 2016 09:44 AM #168After reading that argument that it's ok to keep it at D, I gave it a try this morning. My vehicle would slowly creep forward with the handbrake engaged. Handbrake issues or not, N na lang talaga ako for safety.
sent via Tapatalk
January 17th, 2016 11:08 AM #169
January 17th, 2016 06:45 PM #170
I'm not sure if what I'm experiencing is shift shock but the transmission jerking is more pronounced from D to N than N to D. In fact, N to D is quite smooth and jerking is almost non-existent. Without stepping on the brakes or gas pedals, I can shift from N to D and the car will just start to move slowly on its own. 2015 Altis CVT.
Kicks, yes. Leaf, no.
2021 Nissan Leaf
